External WiFi Antenna?
Is there a connector for an external WiFi antenna? If so, what kind of connector is it?
For which module exactly?
I could use any one. I had the base model with the motion sensor in mind.
The M5 Cores - Grey - Black - GO and Fire do not have any connector for external antenna, they only have the soldered on 3D antenna. All of the telecommunications stacks have ports for external antenna.
@lukasmaximus Same question here, but which module use to add an external wifi antenna. I need a longer range.
@leo05 said in External WiFi Antenna?:
Same here - We are using Fire or Core2 + Arduino. In dense environments (a lot of WiFi AP) device simply cannot connect or disconnects after a minute or two. Our options: 1. Add antenna somehow (with some soldering or whatsoever) 2.Add the additional WiFi module with antenna 3. Use other device.
Any thoughts?
