    Simple fix when upload fails.
    49 Posts 16 Posters 357.8k Views 4 Watching
      appie
      Add a small capacitor like 2,2uF between Ground and RST
        mxwang
        good, work!
          mathdb
          If you do not have a capacitor available, you can also try to set the "Upload Speed" to 115200 in Arduino IDE.
          Of course the uploads are longer, but it did the job for me : i did not have any upload error since
          I also installed the latest CP210x Windows driver (v10.1.1 for Windows 10) but i don't think this is necessary
            Stanszal
            I am getting errors when trying to up load, it sees the board but gives he following errors:
            Arduino: 1.8.1 (Windows 7), Board: "M5Stack-Core-ESP32, QIO, 80MHz, 115200, None"
            Sketch uses 351999 bytes (26%) of program storage space. Maximum is 1310720 bytes.
            Global variables use 12024 bytes (4%) of dynamic memory, leaving 282888 bytes for local variables. Maximum is 294912 bytes.
            esptool.py v2.1
            File "esptool.py", line 2524, in <module>
            File "esptool.py", line 2517, in main
            File "esptool.py", line 2246, in main
            File "esptool.py", line 177, in init
            File "site-packages\serial_init
            .py", line 88, in serial_for_url
            File "site-packages\serial\serialwin32.py", line 62, in open
            serial.serialutil.SerialException: could not open port 'COM6': WindowsError(23, 'Data error (cyclic redundancy check).')
            Failed to execute script esptool
            the selected serial port Failed to execute script esptool
            does not exist or your board is not connected
            • JJJ Offline
              JJ
                Stanszal
                I updated the Arduino IDE to 1.8.5 Installed the usb drivers, it still doesn'y work. When the M5 is plugged in it shows up in the device manager and the port is working correctly. so I know the usb port is good. I also tried lowering the transfer sped as suggested and that doesn't help. I will try to find a capacitor some where. It is kind of disappointing that with all the work that went into this it has problems connecting.
                • JJJ Offline
                  JJ
                    Stanszal
                    I tried the cap, here is a screen shot of whats the problem. The pc is seeing the port, it recognises the driver and is working.
                    It is trying to upload, but times out I tried both baud rates neither works.![alt text](0_1515100345875_screen.jpg image url)
                    • JJJ Offline
                      JJ @Stanszal
                        Stanszal
                        I tried reversing the cap, It still won't connect. It still has the same timeout problem. Changing baud rate doesn't help either.
                        • JJJ Offline
                          JJ
                            Stanszal
                            I am using win7 and arduino ide 1.8.5. The board automatically selects the com port when plugged in . The port varies .
                            I have the cap soldered onto dupont leads and have them plugged all the way in. I tried both polarity's
                            I keep getting the "timed out waiting for packet header " error. for whatever reason it won't connect. I have no problems with the ports with various Arduino boards, ESP8266's and ESP32's
                            • JJJ Offline
                              JJ
                              • E Offline
                                ElectroMagus
                                @stanszal 在 Simple fix when upload fails. 中说:
                                As a note, I am having the exact same problem. I'm using PlatformIO, but the esptool output is the same indicating the same underlying error.
                                When I look at the Serial Monitor, it's booted and here is the output:
                                rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                                configsip: 0, SPIWP:0xee
                                mode:DIO, clock div:2
                                load:0x3fff0018,len:4
                                load:0x3fff001c,len:812
                                load:0x40078000,len:0
                                load:0x40078000,len:11404
                                entry 0x40078aa0
                                user code done
                                I recovered mine using the EspressIF ESP32 Download Tool following the M5 guide for loading their MicroPython / Cloud IDE firmware.
                                I wanted to play around with their cloud IDE anyway, but you should be able to use the factory firmware (also on GitHub) or one of the ones in your Arduino compile cache that you know works.
                                Edit: Forgot to mention, I did have to use a 10uf cap across the GND and RST pins as described earlier in the thread in order to get the EspressIf tool to be able to connect.
                                  Stanszal
                                  After much fiddling around I managed to connect to it. However it is unreliable. This thing is a big disapointment. It is obvious a lot of work went into this thing, but they should have put in a little more to get it to work right out of the box.
                                  You can get Various Arduinos, ESP8266's and ESP32's for much less and they just work.
                                  • m5stackM Online
                                    so sorry, pls try this.
                                      Stanszal
                                      try what? add a cap? what type and volts? where can I get 1 cap? how about I send this back and you fix it so it works?
                                      • JJJ Offline
                                        JJ
                                          Stanszal
                                          Here is how I see it, I already spent over $40.00 for this thing. Yes, I can spend another $3.50 and order some caps, wait 5 to 6 weeks for them to arrive and they may or may not solve the problem. If this is a known issue you should have included a cap with the device.
                                          I tried 3 caps, 2 electrolitica and a polyester one. the result is the same, you need to try to upload the sketch multiple times to maybe get it to work once.
                                            Stanszal
                                            JimiT and ElectroMagnus, thank you for your help
