    How use RGB LED on M5 FIRE?
    3 Posts 2 Posters 9.3k Views 1 Watching
      progga
      how can i use the RGB LED's with the new M5 FIRE. I try the Adafruit_NeoPixel library for the SK6812 but my m5 crash at start up.
      code:
      #include "esp_deep_sleep.h"
      Adafruit_NeoPixel strip = Adafruit_NeoPixel(10, 15, NEO_KHZ400);
      strip.setBrightness(50);
      strip.begin();
      strip.setPixelColor(1, 255, 255, 255);
      Does somebody has any idea?
      Thanks.
        frollo555 @progga
        Try Adafruit_NeoPixel.h library. Set pin to 15(GPIO) and number pixels to 10. Enjoy.
        #include <Adafruit_NeoPixel.h>
        #include <M5Stack.h>
        #define PIN 15
        #define NUMPIXELS 10
        Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB);
        int delayval = 500;
        void setup(){
        pixels.begin();
        for(int i=0;i<NUMPIXELS;i++){
        // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
        pixels.setPixelColor(i, pixels.Color(0,0,150)); // Moderately bright BLUE color.
        pixels.show(); // This sends the updated pixel color to the hardware.
        delay(delayval); // Delay for a period of time (in milliseconds).
          progga
          Thank you for you help,
          now I solved the problem with esp32_digital_led_lib library.
          Example:
          [CODE]
          #include "esp32_digital_led_lib.h"
          // Enumberation ob LED's
          // 9 0
          // 8 1
          // 7 2
          // 6 3
          // 5 4
          #define LED_PORT 15
          strand_t m_sLeds = {.rmtChannel = 0, .gpioNum = 15, .ledType = LED_WS2812B_V3, .brightLimit = 32, .numPixels = 10, .pixels = nullptr, ._stateVars = nullptr};
          void Led_Init(void) {
          pinMode (LED_PORT, OUTPUT);
          digitalWrite (LED_PORT, LOW);
          if(digitalLeds_initStrands(&m_sLeds, 1)) {
              E_TRACE("Can't init LED driver()\n");
          digitalLeds_resetPixels(&m_sLeds);
          // Set led 7 to red
          m_sLeds.pixels[7] = pixelFromRGBW(55, 0, 0, 0);
          digitalLeds_updatePixels(&m_sLeds);
          [/CODE]
