    OSError: I2C bus error(19)
    5 Posts 2 Posters 8.7k Views 1 Watching
    • X Offline
      xxxa0c
      Today suddenly stoped working I2C devices on port A.
      After coding session (Wave file playing from SD, developed on c++), I flashed (M5Burner updated to 2.3.0) the UIFlow 1.7.5core2 with well debuged UI application with ENV2 and SGP30 sensors connected through GROVE HUB. At first I got "ENV2 unit not found" while it was connected. Reconnection and cable exchange gave nothing. Core2 did not see ENV2 sensor plugged in PortA through GROVE Hub or Directly.
      Could somebody give any suggestions?
      • X Offline
        xxxa0c
        I measured voltage on 5V line on I2C PortA and found that it is 0. Is it possible to turn it off\on programmatically on it is a DCDC malfunction? (It is strange, Core 2 only 3 months old)
          Hello @xxxa0c
          yes, it is possible to turn it on/off programmatically.
          UIFlow: Hardwares - Power - Set bus power mode Disable/Enable M-Bus 5V output
          Arduino: last parameter of M5.begin()
          void begin(bool LCDEnable = true, bool SDEnable = true, bool SerialEnable = true, bool I2CEnable = false, mbus_mode_t mode = kMBusModeOutput);
          P.S. I believe it should be on by default though.
          • X Offline
            xxxa0c
            GREAT THANKS, Felix! Obviously I turned I2C off during I2S programming session. After I had included the UIblock, that you specified, my sensors and I2C returned to life.
              Hello @xxxa0c
              you are welcome. Glad to hear you got it working again. And thank you for reporting back.
              Cheers
