    Noise on speaker
    16 Posts 10 Posters 59.2k Views 3 Watching
    • reaper7R Offline
      reaper7
      @donck 在 Noise on speaker 中说:
      M5.Lcd.setBrightness(0);
      for me mute and setBrightness to 0 not solve noise problem,
      I still hear that noise :(
        DoNcK
        Just to be clear, to me there are two types of noises:
        Light white noise : I believe this one is probably due to the quality of the audio amplifier.
        A higher pitched noise, much more annoying.
        On my device (M5Stack limited edition), only the 2nd one is affected by the display setting.
        For that second one, not everybody may be able to hear it, depending on multiple factor including aging (presbycusis).
        Update: I received my M5Stack with PSRAM, it behaves exactly the same.
        • reaper7R Offline
          reaper7
          Yes, I hear white noise (I have to put my ear to be heard) + and second one, annoying, audible from a distance.
          I have too M5Stack limited edition
            deshipu
            I also noticed a lot of noise on the speaker, and I can tell that a large part of it comes from the SPI signal going to the display, from the PWM on the display backlight, from the signal on the UART from uploading, and pretty much from every single thing the module does. The reason for this is probably that the audio lines are not designed and shielded properly, and all sort of electrical activity in the module affects the audio signal.
            I noticed that moving the speaker leads under the PCB affects the intensity of the noise in different situations (probably depends on which part it is closer to).
            This is exceptionally poor design, I'm afraid.
            on4aaO 1 Reply Last reply Reply Quote 1
            • on4aaO Offline
              on4aa @deshipu
              @deshipu This is for those who can live without audio and want to safe on power consumption along the way.
              Note that the audio amplifier can be disabled by placing a solder bridge over the two correspondingly marked PCB pads next to the ESP32.
              Serge β€” http://hamwaves.com/iot/
              • JJJ Offline
                JJ
                @on4aa Hi Serge,
                I haven't had any significant ongoing problem with this....
                Regardless, just to clarify for those playing along at home, I take it this is where you suggest the solder bridge - (Edit: photo deleted as it ultimately did not aid the discussion and added unnecessary additional screen scrolling - JimiT.)
                • on4aaO Offline
                  on4aa
                  No, I am talking rather about this optional solder bridge marked with AMP on the PCB:
                  optional AMP solder bridge
                  • on4aaO Offline
                    on4aa
                    With respect to the noise, I hear the following:
                    1. Interference or capacitor noise on every instance when something on the screen is being drawn,
                    2. A very brief high-pitched squeak when the device is connected through USB and the cable temporarily makes a bad contact when being manipulated.
                    There is little that can be done about the first source apart from redesigning the PCB and perhaps replacing certain capacitors with more expensive tantalum variants.
                    As for the second source, I am wondering if we are dealing here with an undocumented audible brown out (i.e. undervoltage) warning. I am using the optional 850mAh battery and I charged my device well before use. By consequence, I do not hear it that often, only when manipulating the USB cable when connected.
                    However, those using the bottom plate battery of a mere 150mAh battery, perhaps without properly charging it, might here the high tone more often or even continuously.
                    I am hoping more users and certainly the designers will chime in here (pun intended) to clarify this situation.
                    • on4aaO Offline
                      on4aa
                      Here is how the audio amplifier can be disabled:
                      AMP power schematic
                        techcntrl
                        If someone still have the issue these two lines should solve the problem
                        ledcDetachPin(SPEAKER_PIN);
                        pinMode(SPEAKER_PIN, INPUT);
                          Calin @techcntrl
                          The solution is much easyer:
                          dacWrite (25,0);
                          L 1 Reply Last reply Reply Quote 3
                          • L Offline
                            Leo05 @Calin
                            @calin Thanks!
                            Precision: dacWrite (25,0); must be in the void loop
                            With your input, this post could be even better πŸ’—
