UnitV2 Linux Firmware?
I've modified the network stack and lost access to the device through usb/wifi, what can i use to reflash the device?
This post is deleted! -
Nvm, i fixed it by altering the firmware file deploy.py using 7zip and notepad++ and adding this text to the deploy file just above "dnsmasq_file = "
Please note the backslash at the end of dhcpcd_file=here is missing (forum problem_
FIX BEGINS HERE - COPY BELLOW THIS LINE
dhcpcd_file =
nohook lookup-hostnameinterface eth0
static ip_address=10.254.239.1/24
static routers=10.254.239.1
open('/etc/dhcpcd.conf', 'w+').write(dhcpcd_file)FIX ENDS HERE
It restored the network on the UnitV2
I am in the same situation, I ask for more details thank you in advance
