    [MQTT-Core] Support for RETAIN
    Scheduled Pinned Locked Moved Features Wish List
    8 Posts 6 Posters 15.0k Views 1 Watching
      marcvl
      RETAIN is an essential feature of any MQTT implementation. Without RETAIN, device information can get lost when a service like Home Assistant who uses MQTT subscription to get device info, has an issue. For instance, when Core sends out an MQTT discovery message (essential for Home Assistant auto-discovery) the RETAIN flag ensures that the device is still available after Home Assistant reboots.
      1 Reply Last reply Reply Quote 5
        marcvl
        Hi: Is there an update to this request? It seems to me that this would be very easy fix ... just adding the 'retain flag' parameter to mqtt messages. This is a very essential feature for mqtt auto-discovery with remote clients (such as Home Assistant). Without retain, Home Assistant loses all the configuration details about the M5Stack device after every HA reboot. The M5stack becomes 'unavailable' to HA and it's only after rebooting M5Stack that the device becomes available again.
        • world101W Offline
          world101
          What all have you tried and are you using uiFlow or Arduino?
          I'm pretty sure they implemented it a while back, as I originally requested it more than a year ago. I haven't tested it recently, but I believe it was working before. Let me do some digging and I'll see what I can come up with.
          • world101W Offline
            world101
            https://community.m5stack.com/topic/1595/mqtt-subscribes-on-uiflow
              saiaman01
              I need it too, in UIFlow.
              1 Reply Last reply Reply Quote 4
                falbriard
                The MQTT Adafruit forum told me: "An automatic process in order to synchronize the subscriber without any data loss?
                You can - please see this documentation about retained values here:
                [https://io.adafruit.com/api/docs/mqtt.html#retained-values](link url) “
                Checking the Github I've found an open issue about support of the MQTT retain Flag in M5 UIFlow code. See: [https://github.com/m5stack/UIFlow-Code/issues/1](link url)
                My PAHO subscriber client currently displays a zero value in the retain flag returned from the M5 publisher and Adafruit broker. Do you know the status of this issue?
                  magister
                  You can edit the UIFlow2 python code to add "retain=True" as that functionality is available in the python library. What is needed is that retain= needs to be exposed in the Block definitions. Otherwise, I'm constantly having to add that back in every time I turn off editing mode.
                  • felmueF Online
                    felmue @magister
                    Hello @magister
                    in the mean time you could try and copy the correct Python statement into an Execute mpy code block. You can find it under System.
