    Librerías ESP32 vs Arduino
    Scheduled Pinned Locked Moved Foro español
    12 Posts 2 Posters 26.7k Views 1 Watching
    • O Offline
      oscillator
      @pirix said in Librerías ESP32 vs Arduino:
      Cómo solventar este problema de librerías entre Arduino y ESP32?
      When I compile for the Core2 I also get warnings, eg:
      Used: /home/staffan/.arduino15/packages/m5stack/hardware/esp32/1.0.9/libraries/SD
      Not used: /home/staffan/Arduino/libraries/SD
      but that doesn't stop my compilation.
      Have you selected the right board in the Tools menu?
        PiriX
        Yes, I did. M5Stack-ESP32
        • O Offline
          oscillator @PiriX
          Strange. Can you post the whole output of your compilation? Maybe there is some earlier error.
          What OS are you running?
            PiriX
            That's what I trying to run
            https://github.com/frittna/Crypto_Coin_Ticker
            I'm on a MacBook Pro 16" Intel i9, macOS Big Sur
              PiriX @oscillator
              @oscillator Arduino: 1.8.16 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
              Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi
              Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi
              In file included from /Users/pirix/Documents/Arduino/Crypto_Coin_Ticker-master/Crypto_Coin_Ticker/Crypto_Coin_Ticker.ino:20:0:
              /Users/pirix/Documents/Arduino/libraries/Timezone/src/Timezone.h:16:66: fatal error: TimeLib.h: No such file or directory
              Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/SD
              compilation terminated.
              Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
              exit status 1
              • O Offline
                oscillator
                Do you have the Timezone library installed?
                In the docs for the Timezone library it says:
                "The Timezone library is designed to work in conjunction with the Arduino Time library, which must also be installed on your system."
                There is also a note in the beginning of the code:
                // !!! Library versions should match to mentioned below !!!
                // !!!!!!!!!!!! Otherwise code won't work !!!!!!!!!!!!!!!!!
                Do you have the right version of the libraries installed?
                  PiriX @oscillator
                  @oscillator Exactly what they recommend
                  • O Offline
                    oscillator
                    You seem to have prepared everything that they want...
                    Also, I am running on GNU/Linux so...sorry, can't help you...
                      PiriX @oscillator
                      @oscillator Thank you so much for your interest!
                      • O Offline
                        oscillator
                        Hmmm, found this: https://forum.arduino.cc/t/timelib-h-no-such-file-or-directory/413110/4
                        I know they talk about Windows, and you run OSX, but maybe this applies to you too?
                          PiriX @oscillator
                          @oscillator Thank you!
