    Custom Prototype Board
    16 Posts 9 Posters 58.9k Views 4 Watching
    • suremicroS Offline
      suremicro
      I used Easy EDA which imported the pcbdoc file after some messing around with the format. I will make the gerber and pcb files files available as well as the 3D prototype enclosure file (with solid edges) soon.
      I have now tried out the new board with a couple of simple jack connectors and all seems to work!
      JJJ S 2 Replies Last reply Reply Quote 2
      • JJJ Offline
        JJ @suremicro
        @zazar Nice design !!! Thanks for the details and the photos.... and for making the files available soon.
          suremicro
          The PCB and 3D case design files can now be found on GitHub at https://github.com/zazardev/M5Stack-Proto
          For those using EasyEDA see https://easyeda.com/suremicro
          • world101W Offline
            world101
            This is excellent. Looks like you are doing a temperature reading (thermistor/thermocouple) setup, which is what I have been working on. Are you using a voltage divider to calculate temperature? If so, please provide your schematic.
            Also, can you provide part numbers for the input jacks (2.5mm I assume)? I have some panel mount jacks that were for another case enclosure, but they are too big for the m5stack. Yours look great.
            How accurate is the temperature? I've been reading the ESP32 ADC can be not quite linear and therefore not so accurate. So I was looking into another ADC breakout module like the ADS1115 for more resolution bits and accuracy.
              suremicro
              Yes the device will be used to record multiple temperatures using DS18B20 sensors on one wire with a single 4.7k resistor. I hooked up 5 and can read them indiviudally since they have there own addresses. I only need the temperature to the nearest degree so they are fine for my purposes.
              I actually use a 3.5mm jack and bought a few connectors as like you found that many do not fit, however the very small SMD mounted ones just fit in the standard case. The ones I found are on Amazon:
              https://www.amazon.co.uk/dp/B008SO0E60/ref=pe_3187911_189395841_TE_3p_dp_1
                sibtcha
                Hello, your prototype board is very usefull, more than the genuine one.
                It's possible to order a set from EasyEDA ?
                  suremicro
                  Yes, if you head over to https://easyeda.com/suremicro the design is there which you can use to get your own boards made. I used JLCPCB.
                  • O Offline
                    Omoe @suremicro
                    @suremicro 在 Custom Prototype Board 中说:
                    Yes, if you head over to https://easyeda.com/zazarltd the design is there which you can use to get your own boards made. I used JLCPCB.
                    Haven't used JLCPCB, I've used Seeedstudio Fusion service https://www.seeedstudio.com/fusion_pcb.html a few times. They are especially good if you need several of the same board as they send 10 copies
                      saiaman01 @suremicro
                      @suremicro sorry its been a long time, but do you still have pcb/3D case somewhere ?
                      Gonna github / easyeda ... nothing found :(
                        Hello @saiaman01
                        don't know about the PCB, but the 3D case is here.
