    M5Core detects pressure on key A even if the key was not pressed at all.
    4 Posts 2 Posters 7.3k Views
      Peter
      I discovered by accident that the M5Core sends out a command via MQTT, even if the associated button was not pressed at all. Has anyone ever observed something similar. What can be the reason. It only occurs with key A.
      I have written a program to control my marquee in UIFlow. Here is the resulting Micropython code:
      def buttonA_wasPressed():
        global temp, prog_name, lfd_nummer, version, data_update, balkon, wohn_zimmer, testraum, message
        m5mqtt.publish(str('whg/balkon/markiese/strg'),str(lfd_nummer))
        lab_status.setText(str(lfd_nummer))
        lab_status.show()
        lfd_nummer = (lfd_nummer if isinstance(lfd_nummer, Number) else 0) + 1
        pass
      btnA.wasPressed(buttonA_wasPressed)
      Unfortunately, the indentations are swallowed. Is there a way to format code?
      Peter
        Hello @Peter
        could be the issue discussed here. Or this one. Not sure how to fix though.
        Yes, you can mark a code block using the back tick three times in a row ``` at the beginning of the line before and after the code block.
        P 2 Replies Last reply Reply Quote 0
          Peter @felmue
          Thank you for the information.
          I will have a look at the links. At first glance it might fit.
          Peter
            Peter @felmue
            The tip has hit the problem. I have implemented a query of the key A in the callback routine after 1 ms. Only if the key is still pressed the routine is executed. Otherwise nothing is done. Now there are no more key presses from the ghost.
