M5Paper on macos Big Sur
@ajb2k3 said in M5Paper on macos Big Sur:
Ok, I have found that there is currently an issue in OSX in that the driver is randomly not being loaded for the adapters.
It consistently fails to load, not randomly. At least that's the case for me.
What's your source?@m5stack Can you confirm is this was tested on Big Sur 11.4 ?
Unless someone can confirm they have has it working on that specific version it's more than likely the driver was not built for this OS.There are over 550 kernel extensions on my mac and they all work perfectly. It seems the interface Apple exposes for loading extensions works for everyone else.
@m5stack
For general information Silicon Labs has a newer version of the driver which I can load.
But that does not work either :(https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers
Was working on 10.14 but 10.15 fails.
@nigel Im on Catalina (just upgraded from Mojave) and now have the issues :(
hello I got the exact same issue with my mac book pro, I will add some more details, I am using the default apple mac https://www.apple.com/shop/product/MUF82AM/A/usb-c-digital-av-multiport-adapter and then the Burner app, it does display the same option ttyusbmodem something. It would be great to find a workaround to be able to updgrade the firmware and start innovating ;)
I found an issue with the driver and had to select the kext file and now the driver works and usb serial is now working again!
Hi @ajb2k3 what do you mean by selecting the ktext file, something like
sudo kextload SiLabsUSBDriver.kext
me it does not change anything, I am on OS Catalina
@darul75 said in M5Paper on macos Big Sur:
Select? wow autocorrect!
Nope, It should read delete.
OSX has another driver that is conflicting with the slabs driver. -
I will try to do so deleting it
@ajb2k3, what .kext did you delete? I can see that there is a conflicting driver but I can't figure out which one.
