    USB communication
    Scheduled Pinned Locked Moved Lessons and Guides
    4 Posts 2 Posters 7.5k Views
    • B Offline
      brvus76
      Dear All,
      I like UIFlow but I am not an expert of Python. I have always programmed through the standard Arduino IDE.
      I need to interface my M5Stack Core 2 with MegunoLink. This can be easily done if I use the standard IDE, but I am not able to do it with UIFlow.
      Basically I need to send to my PC through the USB a set of strings such as: {XYPLOT|DATA|Name|x|y}
      Could you help me?
      Thank you very much
      Bruno
      • felmueF Online
        Hello @brvus76
        have you tried the print block? You can find it under Text.
        • B Offline
          brvus76 @felmue
          Dear felmue,
          At first thank you very much for your answer. I apreciate this.
          I tried. It works (!) but I have some problems. First of all, the data transmission is really slow. I tried to modify the row:
          print((str(((str(((str(((str('{XYPLOT|DATA|Analog Measurements|') + str(tt)))) + str('|')))) + str((adc0.read()))))) + str('}')))
          with
          print("{XYPLOT|DATA|Analog Measurements|}, tt, "|", adc0.read(), "}")
          but without success.
          Another problem is that when I open the USB communication from my software on the PC the M5 has a reset...
          Could you help me?
          Thank you!
          • felmueF Online
            Hello @brvus76
            I don't really know why the communication might be slow. I can only guess that UIFlow firmware maybe has some safeguards in place to prevent serial from flooding the line.
            I guess that your software on the PC manipulates the control lines (CTS, etc.) on the serial port in a way which triggers the auto download / reset mechanism in M5Core2. Unless there is some setting in your software to configure that behavior I don't think there is much you can do.
