    M5STACK CORE 2 SOUNDS
    5 Posts 3 Posters 9.0k Views 1 Watching
      danbicks
      Ladies and gents I have been struggling to work out the best way to convert wav files to C arrays for playing sound using I2S audio output. Has anyone got a clearly documented solution for this. Would have been great in the examples to also include this in future releases. The 2 sounds work fine supplied with the core 2 however no guidance on how one goes about creating their own. All help appreciated. Thanks
      • E Offline
        erich
        On the same topic it would really be great adding in the C++ M5Core2.h lib a method to play simple beeps.
        I just need to beep on button press but it looks like I have to load a .C sound file in the Core2 flash memory which is totally overkill.
        If someone has an idea how to play simple beep without loading a file can you please help me?
        Thanks a lot!
        • E Offline
          erich
          I came across this post right after posting here:
          https://community.m5stack.com/topic/3179/how-to-generate-a-beep
          The solution suggested by @AgreeDK does perfectly work! (thanks to you!)
          I would however really like M5 people to update the Core2 lib with a simple beep function like on the Core
            I have written a guide but its for Micropython but it does specify the exact audio specifications.
            • E Offline
              erich @ajb2k3
              @ajb2k3 As I mentioned in the other post my code is written in C (VSCode + PIO) however I would like to try Micropython for my next project M5Stuff project :)
              Can you please tell me more about your guide? Is it possible to buy it somewhere? is it the same as what is mentioned in your signature: UIFlow handbook? I would be very much interested, thanks!
