    89 Posts 25 Posters 446.8k Views 10 Watching
    • frittnaF Offline
      frittna @yashax
      @yashax said in Bitcoin / Multi Crypto Coin Ticker with 24 candlesticks chart:
      The new M5Burner does not allow to select the zip file to burn.
      what do you mean?.. try downloading new from source and follow readme
      • Y Offline
        yashax
        • frittnaF Offline
          frittna @yashax
          Thank you. What is the location of the M5Burner source?
          you find the link is in the first post
          download project: https://github.com/frittna/Crypto_Coin_Ticker
            frankchau93 @frittna
            @frittna
            Hi there,
            I have a Core 2 and I want to install this. I tried doing this on windows with the installer, however the SD card library isn't compatible with the Core 2, according to this post: https://github.com/frittna/Crypto_Coin_Ticker/issues/3
            Can you compile a version with a SD card library that works? This looks so cool and i really want to try this out!
            • frittnaF Offline
              frittna @frankchau93
              @frankchau93
              i started from zero too so maybe give it a try and search/test if there are other compatible libraries. Since i have no core2 device and beside the (stupid) fact that i cannot use the latest boardmanager (higher than 1.0.4) on a core1 I am kind of stuck. But i guess not forever.. atm i am not really plessed with free time but we would need to know what is causing the problems with boardmanager 1.0.5 and higher first. I suspect the WIFI, the SDCard or the Websockets library. Then only minor changings in code are needed to support core2 i guess.
              • Y Offline
                yashax
                Can someone please help me figure out how to display ticker for TIME crypto coin?
                • Y Offline
                  yashax
                  Is it possible to have ticker rotate between several crypto coins? Like BTC for 5 seconds, the ETH for 5 seconds, in the loop.
                  • frittnaF Offline
                    frittna @yashax
                    @yashax
                    regarding TIME token - I see 4 different tokens with that name but none of it is listed on binance.
                    An optional cycling function like you're asking was added in the last version i've released a month ago.
                    Scroll up or go to the github source page.
                    btw: do you have a core1 unit now?
                    • Y Offline
                      yashax @frittna
                      @frittna Yes, picked up 2 Core 1’s with stands. ))
                      Regarding TIME, so if it’s not listed on Binance, it won’t work?
                      Thank you for all your help.
                      J
                      • frittnaF Offline
                        frittna @yashax
                        @yashax
                        yes, thats correct since prize data comes from the binance api only, spot markets, no derivates
                        • Y Offline
                          yashax
                          How can I change clock from 24hr to 12hr?
                          Thank you
                          • frittnaF Offline
                            frittna @yashax
                            you can check at line 500 in the code and simply change lines where is says "time(now)" to "timeFormat12(now)"
                            this will work and will show time in am/pm mode and not in 24h mode.
                            If you want to have a visualisation for am/pm too you would have to find free space first and draw something small with a the isAM() or isPM() function.
                            • Y Offline
                              yashax @frittna
                              @frittna Thank you so much.
                              What’s the while line on the chart?
                              • frittnaF Offline
                                frittna @yashax
                                @yashax
                                the white line is the relative trading volume from the last 24 shown candles
                                • Y Offline
                                  yashax @frittna
                                  @frittna Can you please be kind to help me to adapt your code to display the Forex market, the same way.
                                  Thank you so very much in advance.
                                    dssguy1
                                    Recently my ticker just went to 0.00e+00 for BTC price and no chart. It says "WS Disconnected" now. Did something in the data source change to break this awesome little ticker?
                                      dssguy1
                                      Forgot to mention, it also says "No JSON in response".
                                      • B Offline
                                        bucket62
                                        I am also getting the W.S disconnected and no JSON message. Is there a way to update the config file so that users can change the API? I think this may be a problem with the binance API
                                        • frittnaF Offline
                                          frittna
                                          maybe it could be geo-blocked because here from the EU for example it still works normally!
                                          please test:
                                          https://api.binance.com/api/v3/depth?symbol=BTCUSDT&limit=1000
                                          and
                                          https://api.binance.us/api/v3/depth?symbol=BTCUSDT&limit=1000
                                          If only the .us domain works for you i will update the code soon for an .us version.
                                          If you compile it yourself with arduino you have to modify the .com to .us - so change these two lines:
                                          const char restApiHost = "api.binance.us";
                                          and
                                          const char wsApiHost = "stream.binance.us";
                                            Hello @frittna
                                            FWIW: here in Switzerland both URLs work for me.
