Core2 with W5500 and ESP-IDF
I used a Core2 with W5500, ESP-IDF V4.3.2 and the express example:
../examples/ethernet/basic/main/ethernet_example_main.cThe program started and I got an reset error:
... I (369) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. E (479) w5500-mac: w5500_reset(228): reset timeout E (479) w5500-mac: emac_w5500_init(610): reset w5500 failed I (479) gpio: GPIO[34]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 E (489) esp_eth: esp_eth_driver_install(204): init Mac failedI used this configuration on menuconfig:
Espressif IoT Development Framework Configuration Ethernet Type (W5500 Module) ---> (1) SPI Host Number (18) SPI SCLK GPIO number (23) SPI MOSI GPIO number (19) SPI MISO GPIO number (26) SPI CS GPIO number (5) SPI clock speed (MHz) (34) Interrupt GPIO number (13) PHY Reset GPIO number (1) PHY AddressI changed ESP-IDF version, I set Reset GPIO number to -1, I changed SPI clock to 20 Mhz... -> Every time I got the same error.
Do any one have an idea?
Bye,
Uwe -
Hello @felmue,
thank you very much.
I changed in the file Kconfig.projbuild the range of parameter EXAMPLE_ETH_SPI_MISO_GPIO to 38 and used your values. It worked fine.
Ethernet Type (W5500 Module) ---> (1) SPI Host Number (18) SPI SCLK GPIO number (23) SPI MOSI GPIO number (38) SPI MISO GPIO number (26) SPI CS GPIO number (5) SPI clock speed (MHz) (34) Interrupt GPIO number (19) PHY Reset GPIO number (1) PHY AddressMy challenge was that I hadn't used the Core2-values the last time I made changes. I overlooked this.
Bye,
Uwe
