Atom Lite, interrupt not working as expected
The following code does not work. The LED flickers, no matter what the signal on the used pin is. Tested on two Atoms. Also tested different mode (RISING, FALLING, CHANGE). The code is from Arduino site:
#include <M5Atom.h>
const byte ledPin = 22;
const byte interruptPin = 19;
volatile byte state = LOW;void IRAM_ATTR blink()
state = ~state;
}void setup()
pinMode(ledPin, OUTPUT);
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), blink, FALLING);
}void loop()
digitalWrite(ledPin, state);
}Anyone an idea to solve this?
Solved this finally. The Atom Lite does not seem to have a pullup or pulldown resistor. By applying a resistor the problem seems to be solved and it is possible to detect Rising, Falling and Change states.
