    M5Burner does not work in MacOX 12.3.
    m5 burneruiflow
    18 Posts 12 Posters 33.9k Views 5 Watching
    • W Offline
      waqast @yopita
      @yopita
      https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139#issuecomment-1014816668
      It worked for me
      System:
      MacOS Monterey 12.3.1 (Macbook Pro 2019 Intel)
      Device
      M5Stack Core2
      • Install the driver CH9102_VCP_MacOS_v1.7 > CH34xVCPDriver.pkg
      • Run the app CH34xVCPDriver in Applicatoins
      • GO TO Security on Settings and allow the app to run
      • Start Terminal App.
      • Install homebrew.
        Please refer to the installation on the page : https://brew.sh/
      • Install python3
        Please type the command.
        $ brew install python3
      • Put a symbolic link
        $ sudo ln -s /usr/local/bin/python3 /usr/local/bin/python
      • Start M5Burner on Terminal
        $ /Applications/M5Burner.app/Contents/MacOS/electron-m5burner-v2-eletron
      • Select COM port wchusbmodem
      W R 2 Replies Last reply Reply Quote 0
      • W Offline
        westwoodhk @waqast
        @waqast
        I couldn't solve it.
        When I input this command
        it comes out this message
        ln: /usr/local/bin/python: File exists
        Do someone know how to solve this?
          You need to set the path in BASH's environment setting (if bash is still used) google for setting Micropython Environmental Patch in OSX. I can't help because my OSX is several version behind and won't be updated until I can afford to by a new MAC.
            rickkaye @waqast
            @waqast When I follow these instructions, wchusbmodem does not show up as an available port in M5Burner. I checked in /dev and it is not there. The only port that M5Burner offers to me is /dev/tty.Bluetooth-Incoming-Port. My hardware is 2017 iMac5k MacOS Monterey12.3.1, M5Stack Core. Can anyone help?
            oyoujiO ajb2k3A 2 Replies Last reply Reply Quote 0
            • oyoujiO Offline
              oyouji @rickkaye
              @rickkaye Try to turn M5stack off, then plug it in! Do not turn it on by yourself.
                ajb2k3 @rickkaye
                @rickkaye Take a look in "Security and preferences" to see if the driver has been blocked.
                  plusulli
                  I updated today to macOS Monterey V 12.3.1 and everything is fine with M5Burner MacOS x64 v3.0
                    mashimolab
                    hello,
                    I could resolve the problem by changing the part of putting a symbokic link like below.
                    sudo ln -s /opt/homebrew/bin/python3 /usr/local/bin/python
                    The install path of python3 with homebrew is changed to /opt/homebrew/bin directory as the default in M1 mac.
                    System:
                    MacOS Monterey 12.3.1 (Macbook Pro 2021 M1 Pro Max)
                    Device
                    M5Stack Fire
                    • Y Offline
                      yu_with_a_mission
                      @yopita
                      I tried you way and get another error,
                      "File"/Applications/M5Burner.app/Contents/Resources/packages/tools/serial/tools/list_ports_osx.py", line 32, in <module>
                      kIOMasterPortDefault = ctypes.c_void_p.in_dll(iokit, "kIOMasterPortDefault")
                      Burn Failed
                      How can I solve?
                      System:
                      MacOS Monterey 12.4
                      Device:
                      M5StickCPlus
                        ajb2k3 @yu_with_a_mission
                        @yu_with_a_mission said in M5Burner does not work in MacOX 12.3.:
                        @yopita
                        Burn Failed
                        How can I solve?
                        System:
                        MacOS Monterey 12.4
                        Device:
                        M5StickCPlus
                        There is an Issue Montery.
                        Have you installed Xcode from the App Store?
                        Have you instilled the latest Python 3 from the python site?
                        Have you installed the drivers?
                        Have you set the PATH variable correctly?
                        Have you copied the M5Burner V3 to the Applications folder?
                        Have you erased the controller first before writing the correct firmware?
