    CoreInk wakeup from USB power
    14 Posts 2 Posters 20.6k Views 1 Watching
      Hello @IndianaTux
      this is an odd one. The fact that pressing the reset button in the back restarts the M5CoreInk in question tells me that it has never actually shut down in the first place.
      The shutdown() function does some display cleanup and then sets GPIO12 to low. I wonder if the cleanup somehow gets stuck and therefore the statement to set GPIO12 to low never is executed?
      What happens if you replace M5.shutdown() in your example with digitalWrite(POWER_HOLD_PIN, LOW);? Does that help?
      I 2 Replies Last reply Reply Quote 0
      • I Offline
        IndianaTux @felmue
        @felmue Did not think of trying that. Will try to do that tonight.
        As I needed to ship I replaces the M5.shutdown() with the following:
        void shutdown(void) {
          while(1) {
            esp_sleep_enable_timer_wakeup(100*1000000);
            gpio_wakeup_enable(GPIO_NUM_37, GPIO_INTR_LOW_LEVEL);
            gpio_wakeup_enable(GPIO_NUM_38, GPIO_INTR_LOW_LEVEL);
            gpio_wakeup_enable(GPIO_NUM_39, GPIO_INTR_LOW_LEVEL);
            esp_sleep_enable_gpio_wakeup();
            esp_light_sleep_start();
            if( esp_sleep_get_wakeup_cause() != ESP_SLEEP_WAKEUP_TIMER) {
              ESP.restart();
        In my use case I display a message telling the user to toggle the black switch to power it back up. If it runs out of battery while in that loop, plunging in the USB-C power will make it reboot.
        I'll let you know tonight about your suggestion.
        What s really strange is that it's 100% constant. MAC address 4C* all exhibit the issue while all 94* ones work great.
        • I Offline
          IndianaTux @felmue
          @felmue SO I modified a bit my test script so it's easier to read and replaced M5.shutdown() by digitalWrite(POWER_HOLD_PIN, LOW);:
          #include <M5CoreInk.h>
          Ink_Sprite InkPageSprite(&M5.M5Ink);
          void displayString(char *);
          // Initial setup
          void setup()
            Serial.begin(115200);
            // Initialize the M5Stack object
            if( !M5.M5Ink.isInit())
              Serial.println("Init failed");
              while (1);
            // Clear screen and display hello world
            displayString("Hello World !");
            M5.update();
            if(M5.BtnUP.wasPressed() || !digitalRead(GPIO_NUM_37)) {
              Serial.println("Up pressed");
              // Clear the screen and display "Sleep"
              displayString("Sleep");
              // Shutdown
              // M5.shutdown();
              // Clear the screen and display "Alive"
              displayString("Alive");
            Serial.flush();
          void displayString(char *data) {
              M5.M5Ink.clear();
              delay(1000);
              if( InkPageSprite.creatSprite(0,0,200,200,true) != 0 ){
                Serial.printf("Ink Sprite creat faild");
              InkPageSprite.drawString(35,50,data);
              InkPageSprite.pushSprite();
          With digitalWrite(POWER_HOLD_PIN, LOW); the device does not even shutdown... It just goes on and displays "Alive" on the devices with MAC address 4C.
          FYI last night I tested 24 CoreInk modules. 4 have the MAC address starting with 94 and work great, and the other 20 which all have MAC address starting with 4C all fail.
          I did e-mail support but no response yet.
            Hello @IndianaTux
            ok, so if setting POWER_HOLD_PIN to LOW doesn't shutdown the device then something else is probably keeping it alive. According to the schematic USB, the power button, the hold pin and the RTC can wake up / keep alive the device.
            • Maybe the power button is stuck? (but on 20 devices?)
            • Maybe some component got soldered on incorrectly?
            • Maybe the RTC is in alarm state, creating an interrupt and holding INT LOW?
            The last one you could test. According to the schematic the INT output of the RTC is also connected to GPIO19. So if GPIO19 reads LOW it would mean that INT is LOW and that would prevent the M5CoreInk from shutting down.
            • I Offline
              IndianaTux @felmue
              @felmue So I modified my above script to show the GPIO19 state on the screen:
                  M5.M5Ink.clear();
                  delay(1000);
                  if(digitalRead(GPIO_NUM_19)) {
                    InkPageSprite.drawString(35,70,"GPIO_19 = HIGH");
                  } else {
                    InkPageSprite.drawString(35,70,"GPIO_19 = LOW");
              And it always show HIGH...
                Hello @IndianaTux
                thank you for reporting back. I guess that means it is not USB, not the HOLD_PIN, not the RTC and most likely not the power button which keeps your M5CoreInks alive.
                At this point I must assume some missing component, like a missing pullup resistor R32 or a missing pulldown resistor R33, or some short circuit keeping the devices alive.
                I am curious to hear what M5Stack support eventually comes back with.
                • I Offline
                  IndianaTux @felmue
                  @felmue Yeah they are supposed to come back to me on Monday.
                  • I Offline
                    IndianaTux
                    Ok sorry for not posting this sooner. This is the answer from support:
                    We have replaced the USB-Serial chip, from CP2104 to CH9102. These two are pin-to-pin compatible, seems no issue feedback before. You can add before code before shut down the device. It should work.
                    pinMode(1, OUTPUT)
                    digitalWrite(1, 0)
                    // then pull down gpio12 to power off
                    I have not tried it yet but wanted to post it here before I myself loose the e-mail...
                      Hello @IndianaTux
                      that is interesting. I am curious about whether this actually works.
                      BTW: looks like the proposed fix has been included in the latest M5CoreInk library.
                      • I Offline
                        IndianaTux @felmue
                        @felmue I finally got around to testing this on a 94 and 4C MAC address CoreInk and there is still a big difference.
                        I used the same code I used before to test but upgraded the library to v0.0.6 which has the GPIO 1 fix.
                        With a 94 part when you do the M5.shutdown() the 5v and 3.3v output on the header goes down to 0V showing that the device really powered off and any external circuit that uses this will also power off and not drain the battery.
                        However, on a 4C part with the same exact code, the 5V and 3.3v output remain active. So any electronics that use these will still be powered and will drain the battery...
                        Sent this to support and I hope they will have a fix...
                        • I Offline
                          IndianaTux @IndianaTux
                          Ok further testing and it seems like if I do:
                              M5.shutdown();
                              esp_deep_sleep_start();
                          I'm getting what I expect as a behavior for a shutdown. When running on battery doing these 3 commands makes ESP-32 shut down and the output 5v and 3.3v drop to 0v. And connecting power to the USB-C connector makes the ESP-32 boot back.
                            Hello @IndianaTux
                            does that work with real loads (and not just the multimeter) attached to the output? I am asking because it looks like the MOSFET keeps conducting after M5.shudown() is called and only putting ESP32 into deep sleep (and by doing so reducing the current) makes the MOSFET to finally open. If my thinking is correct a real load on the output would keep the current high and thus the MOSFET closed. (I hope I am wrong.)
                            • U user_m5stack471 referenced this topic on
