    Edukit ATECC608B & AWS IOT & UiFlow
    35 Posts 4 Posters 89.5k Views 1 Watching
      Hello @ajb2k3
      thank you. I appreciate all your help. Unfortunately for some reason I cannot get it to work on my side. Whatever steps I execute before, every time I try to execute ID_0 = unit.get(unit.ID, (21,22)) my M5Core2 crashes.
        ajb2k3 @felmue
        @felmue Sorry, you need to import unit
        Then import units then from units import _ID
        also the code is
        import units
        import unit
        however you can also use:
        import units
        import unit
        ATECC = unit.get(unit.ID, (21,22))
        I don't know why both unit and units (with an S) must be called but they both do.
          Hello @ajb2k3
          thank you again. I tried both your code sequences - still no luck. M5Core2 still reboots after the last command.
          Which UIFlow firmware version is running on your M5Core2?
            ajb2k3 @felmue
            @felmue ok, its been working all day and now crashing
            1.10.2
            OK if you make 1 single mistake, you to to disconnect and power down the Core2 to empty the memory
            this works.
              Hello @ajb2k3
              at this point I think whether the commands succeed or result in a crash depends on the amount of free memory.
              With a freshly rebooted M5Core2 the following commands (sometimes) can be executed w/o crash.
              >>> import unit
              >>> print(ID_0.wakeup())
              True
              >>> print(ID_0.readConfigZone())
                File "units/_ID.py", line 186, in readConfigZone
                File "units/_ID.py", line 363, in read
                File "units/_ID.py", line 377, in read_output
                File "units/_ID.py", line 161, in idle_mode
                File "i2c_bus.py", line 100, in write_list
              OSError: I2C bus error (110)
              True
              >>> print(ID_0.revisionNumber)
              bytearray(b'\x00\x00`\x03')
              Note: The commands need to be executed manually one by one.
              Note: I don't need the import units nor the from units import _ID commands.
                ajb2k3 @felmue
                @felmue said in Edukit ATECC608B & AWS IOT & UiFlow:
                Hello @ajb2k3
                >>> import unit
                True
                True
                Agreed, once the error occurs then memory gets filled requiring hard reset.
                You didn’t need unit or the from? I will try again later.
                I have spent all weekend writing up the atecc for my av2 book including logging the MP modules. I’ll try without those two line tonight.
                  The issue of found was that the basic unit functions are in the unit module with unit.ID being empty but the ATecc function are all in units._ID
                    @felmue try adding the following before defining ID_0
                    From esp import gc
                    gc.collect.
                    This should help clean up some memory.
                    Nope that was wrong. the min code I can get running is
                    import unit
                    import units
                    import gc
                    gc.collect()
                    Oh cool, I got import units._ID to work.
                      @gabrielgc75 @felmue I now present to you the configuration loaded from the ATECC608b in my Core2 AWS
                        Hello @ajb2k3
                        thank you. I've tried to add the gc.collect() command. The result is still not 100% persistent. From time to time I still get a crash.
                          ajb2k3 @felmue
                          @felmue thanks for letting me know. It’s been stable for the testing but I’m yet to move beyond. I tried looking at provisioning for vets and codes but my brain is not taking it in hence the low level MP stuff.
                          I’m sure there will s an issue with MP but I don’t deal directly and not getting feedback from @m5stack or @IAMLIUBO
