    Power Input
    3 Posts 2 Posters 3.6k Views
    • B Offline
      bexybot
      Hello everyone,
      I have some questions about powering the Core2 module:
      1. Currently, if the device is turned off and is connected by USB-C, it turns on. I would like to know if I put the 5V bus in input mode and feed it 5V the same thing happens.
      2. I was wondering what is the best way to detect the 5V input turning off to turn off the Core2 since there is a battery and it could stay on. Any ideas?
      Thanks very much for your help!
      Fábio Dias
      • B Offline
        bexybot
        So with a bit of research, I develop this simple code that makes exactly what I was asking here:
        #include <M5Core2.h>
        #define DEVICE_TIMEOUT 120000
        float Time_bat = 0;
        void setup{
          M5.Axp.SetBusPowerMode(1);
        void loop{
          M5.Lcd.drawString(("Battery: " + String(M5.Axp.GetBatteryLevel())), 0, 120, 2);
          if(!M5.Axp.isVBUS() && !M5.Axp.isCharging()){
            M5.Lcd.drawString(String((millis() - Time_bat)/1000,0) + "         ", 1, 154, 1);
          }else{M5.Lcd.drawString("Feeded             ", 1, 154, 1);}
              if(Time_bat == 0){Time_bat = millis();}
              if((millis() - Time_bat) > DEVICE_TIMEOUT){M5.shutdown();}
          }else{
            Time_bat = 0;
        Hope it helps someone!
