Canvas don't work on M5Stack Core 2
I'm try run simple code:
import lvgl as lv def LV_IMG_BUF_SIZE_ALPHA_1BIT(w, h): return int(((w / 8) + 1) * h) def LV_IMG_BUF_SIZE_INDEXED_1BIT(w, h): return LV_IMG_BUF_SIZE_ALPHA_1BIT(w, h) + 4 * 2 def LV_CANVAS_BUF_SIZE_INDEXED_1BIT(w, h): return LV_IMG_BUF_SIZE_INDEXED_1BIT(w, h) CANVAS_WIDTH = 50 CANVAS_HEIGHT = 50 # Create a buffer for the canvas cbuf= bytearray(LV_CANVAS_BUF_SIZE_INDEXED_1BIT(CANVAS_WIDTH, CANVAS_HEIGHT)) # Create a canvas and initialize its the palette canvas = lv.canvas(lv.scr_act(), None) canvas.set_buffer(cbuf, CANVAS_WIDTH, CANVAS_HEIGHT, lv.img.CF.INDEXED_1BIT) canvas.set_palette(0, lv.color_hex(0x00ff00)) canvas.set_palette(1, lv.color_hex(0xff0000)) # Create colors with the indices of the palette c0 = lv.color_t() c1 = lv.color_t() c0.full = 0 c1.full = 1 # Transparent background canvas.fill_bg(c1, lv.OPA.TRANSP) # Create hole on the canvas for y in range(10,30): for x in range(5,20): canvas.set_px(x, y, c0)An error occurs when running the code.
Traceback (most recent call last): File "<stdin>", line 19, in <module> AttributeError: 'NoneType' object has no attribute '__dereference__'But everything works in the lvgl simulator.
@pavelprosto Its very hard to diagnose issue in MP as sometimes the error message does not actually point to the issue!
The error could be
canvas.fill_bg(c1, lv.OPA.TRANSP)or
canvas.set_palette(1, lv.color_hex(0xff0000)) -
code:
import lvgl as lv canvas = lv.canvas(lv.scr_act(), None)error:
Traceback (most recent call last): File "<stdin>", line 2, in <module> AttributeError: 'NoneType' object has no attribute '__dereference__'
