    Cahnge Font Size in Python
    22 Posts 6 Posters 112.8k Views 4 Watching
    • lukasmaximusL Offline
      To my understanding the fonts supported by micropython are bitmap fonts and are thus unscalable. However there are bigger and smaller sizes of some of the fonts on the M5 for instance the dejavu font has 12pt, 18pt and 24pt.
      You can set the font by calling the command
      lcd.font(lcd.FONT_DejaVu24)
      micropython only supports .fon files an otherwise outdated font format. I managed to find a handful of other .fon fonts and put them in the fonts folder in the m5's flash. However thats not enough to use those fonts, they need to be setup in whichever script relates to the font, and I have not found it yet, no mention in the lcd module of the fonts.
      I will keep trying to add more fonts and if I have any progress I will report my findings here
      • yuriklebY Offline
        yurikleb
        Have you tried:
        lcd.compileFont(file_name [,debug])
        https://github.com/m5stack/M5Cloud#lcdcompilefontfile_name-debug
          I've tried the lcd.compileFont(file_name [,debug])
          with a .c extension font I created with this handy online ttf font to .c converter
          https://littlevgl.com/ttf-font-to-c-array
          I haven't had any luck so far, just results in errors or no response
          will keep trying
          • loborisL Offline
            loboris @lukasmaximus
            @lukasmaximus
            You can use ttf2c_vc2003.exe to convert the ttf fonts to c files and compile it in MicroPython. It works.
              devros
              hello also tried to compile font
              prepared font with ttf2c_vc2003.exe and uploaded to M5stack
              but python returns
              lcd.compileFont('/flash/impact.c', debug=True)
              memory allocation error
              False
              any idea whats wrong?
              impact.c is 160kb size (i need bigger letters)
              • loborisL Offline
                loboris
                @devros
                lcd.compileFont() function reads the whole .c file into the memory buffer allocated on the esp32 heap and in your case there is obviously not enough free heap space.
                I'll try to change the function to read the source file in smaller increments so that large files can be compiled.
                Until then, if you can post your .c file here or somewhere else, I can try to compile it for you and send you the compiled .fon file.
                You can post your questions and issues related to MicroPython port used on M5Stack also on its Forum.
                  devros @loboris
                  @loboris
                  thanks, dont want to waste your time...
                  looks like about 100kb is maximum
                  hmm or can i run micropython virtualy on computer and compile font myself?
                  tried about 80kb size font (80px size) on m5stack and it works (only font looks little croped form left side on some letters) :) thanks
                    I saw about the ttf2c_vc2003.exe on your github but as I am predominately a mac user and my windows machine is in for repair at the moment, I thought it would be good to offer an alternative to others in a similar situation. I tried wine but get errors and so am unable to use the tool. I compiled a bunch of fonts but always tend to get error messages like this https://ibb.co/bZBCoV Does that mean the file size is too big? I succesfully compiled the vera font you included on your github so I know the main issue i'm facing is with the conversion from ttf to c.
                    I was wondering what is the big difference between the online tool I found and the windows command line tool. I hope to write a clear guide to make it easy for anyone to use their own custom fonts no matter what platform they are on.
                    Thanks for your awesome work on this micropython port, I'll have a read on the forums and see if I can find more answers to my question
                      devros @lukasmaximus
                      @lukasmaximus
                      hi, im also on mac and ttf2c_vc2003.exe works great with wine. I used brew installation method for Wine and wineconsole ttf2c_vc2003.exe command...
                      File size is limited to 100kb for now
                      • loborisL Offline
                        loboris
                        I'm working on online font converter which will be available on my server.
                        It will convert any ttf font to c source file and/or compiled fon file compatible with this MicroPython.
                        It should be ready in a couple of weeks (I don't have much free time).
                        lukasmaximusL RopR 2 Replies Last reply Reply Quote 0
                          lukasmaximus @loboris
                          @loboris very cool, look forward to trying it out, meanwhile I will find a way to use the tool you suggested, for some reason I have never been able to successfully install homebrew on my mac. BTW I was wondering does it work with non roman fonts? japanese, thai, arabic etc..
                          • RopR Offline
                            Rop @loboris
                            @loboris While you are working on this, could you also make it an output option to create the .h files needed to use the font with Adafruit's gfx library? (See here for details.) Is there any way for me to help?
                            • loborisL Offline
                              loboris @Rop
                              @rop 在 Cahnge Font Size in Python 中说:
                              Maybe, if you can provide the exact and detailed description of the format.
                              • RopR Offline
                                Rop @loboris
                                @loboris Not sure what server you would be running this on. If linux or other unix it should be relatively easy. As per the link I sent earlier:
                                Adding New Fonts
                                If you want to create new font sizes not included with the library, or adapt entirely new fonts, we have a command-line tool (in the fontconvert folder) for this. It should work on many Linux- or UNIX-like systems (Raspberry Pi, Mac OS X, maybe Cygwin for Windows, among others).
                                Building this tool requires the gcc compiler and FreeType library. Most Linux distributions include both by default. For others, you may need to install developer tools and download and build FreeType from the source. Then edit the Makefile to match your setup before invoking make.
                                fontconvert expects at least two arguments: a font filename (such as a scalable TrueType vector font) and a size, in points (72 points = 1 inch; the code presumes a screen resolution similar to the Adafruit 2.8" TFT displays). The output should be redirected to a .h file…you can call this whatever you like but I try to be somewhat descriptive:
                                ./fontconvert myfont.ttf 12 > myfont12pt7b.h
                                • loborisL Offline
                                  loboris
                                  I have finished the font converter (written in Python) for the font format used in this MicroPython port and it works wery well.
                                  I'm working on the web interface now, the online converter will be available soon on my server, after some more testing.
                                  It will also be available as a standalone Python program (should work on any OS).
                                  Some features:
                                  • Converting any ttf font to C source file which can be compiled with tft.font_compile() or included into the build to be compiled into the firmware is supported
                                  • Converting directly to binary fon file which can be used with tft.font() is also supported
                                  • Convert full ascii character set (32 - 127) or only the selected characters
                                  • Adding characters from cp1252 and cp1250 code pages is supported (more code pages will be probably added later).
                                    Including characters like Ä, €, ß, Č, Đ, ž, ø, µ, ° is now supported
                                    I'll try to add support for non-Latin character sets like Cyrillic, Hebrew, Arabic, Chinese, later.
                                  • Font sizes from 8 to 110 pixels are supported
                                  At the moment I don't have enough free time to support conversion to any other format.
                                    devros @loboris
                                    @loboris
                                    thanks :) can test it when its ready ...
                                      Awesome can we share this or do you want to keep the testing to a small number of people?
                                      • loborisL Offline
                                        @lukasmaximus 在 Cahnge Font Size in Python 中说:
                                        It should be ready for use, by "testing" I've meant I would like to get some information if any issue is detected or any improvement is wanted.
                                        I've already found a small "bug", if hebrew characters are included the wrong C file is generated (caused by right to left writting), the bynary fon file is OK.
                                        • world101W Offline
                                          world101
                                          Super old thread, but I'm curious if @loboris's tool still works to convert fonts (ttf or otf) to be used with the m5stack, since the firmware moved to use the mainline MicroPython code base.
                                          I used the tool and created a font (name is Flighter20) and copied it to /flash. When I try to load it, the m5stack crashes.
                                          MicroPython c24d12861-dirty on 2020-08-06; M5Stack with ESP32
                                          >>> os.listdir()
                                          ['Flighter20.c', 'Flighter20.fon', 'apps', 'blocks', 'boot.py', 'emojiImg', 'img', 'main.py', 'res', 'temp.py', 'test.py']
                                          >>> lcd.font("Flighter20")
                                          Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
                                          Core 1 register dump:
                                          PC      : 0x4010a2f5  PS      : 0x00060f30  A0      : 0x80116f3d  A1      : 0x3ffcea40
                                          A2      : 0x00000001  A3      : 0x3f81b150  A4      : 0x3ffceaf0  A5      : 0x00000008
                                          A6      : 0x3ffceaa0  A7      : 0x00000000  A8      : 0x3ffbdbec  A9      : 0x3ffbdbec
                                          A10     : 0x00000000  A11     : 0x00000000  A12     : 0x80096333  A13     : 0x3ffce950
                                          A14     : 0x00000003  A15     : 0x00060023  SAR     : 0x00000020  EXCCAUSE: 0x0000001c
                                          EXCVADDR: 0x00000000  LBEG    : 0x40095234  LEND    : 0x4009523f  LCOUNT  : 0x00000000
                                          ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000
                                          Backtrace: 0x4010a2f5:0x3ffcea40 0x40116f3a:0x3ffcea60 0x400e3be1:0x3ffceaf0 0x400df959:0x3ffceb20 0x400dfa8d:0x3ffceb40 0x400ed9b3:0x3ffceb60 0x400e3cb0:0x3ffcec00 0x400df959:0x3ffcec70 0x400df982:0x3ffcec90 0x4011c6a7:0x3ffcecb0 0x4011c8c1:0x3ffced40 0x400f6f1c:0x3ffced80 0x4009613a:0x3ffcedb0
                                          Rebooting...
                                          ets Jun  8 2016 00:22:57
                                          configsip: 0, SPIWP:0xee
                                          mode:DIO, clock div:1
                                          load:0x3fff0018,len:4
                                          load:0x3fff001c,len:5116
                                          load:0x40078000,len:11608
                                          load:0x40080400,len:6176
                                          entry 0x400806c0
                                          Is there any way to load custom fonts to the m5stack now?
                                            I have a vague recollection that the command lcd.compileFont() was required, I could be wrong though, it's a long time since I experimented with adding fonts
