    [Solved] Connecting 3 ENV units via 1 to 3 Hub to M5 Stack
    20 Posts 11 Posters 37.0k Views 2 Watching
    • m5stackM Online
      m5stack @thbonk
      @thbonk You can refer to these examples. Then combine them
      ENV:https://github.com/m5stack/M5Stack/tree/master/examples/Unit/ENV
      PaHUB:https://github.com/m5stack/M5Stack/tree/master/examples/Unit/PaHUB
      • thbonkT Offline
        thbonk
        @m5stack @sysdl132 I don't get it working. I have connected the PaHUB to my M5Stack and two ENV sensors to the PaHUB.
        When I run the PaHUB demo, it shows the addresses 0x5C, 0x70, 0x75 and 0x76 for channel 0 and 1, and 0x5C, 0x70, 0x75 for the remaining channels.
        I my own program, I added the class TCA9548A and DHT22 (I renamed TCA9548A to PaHUB).
        My setup function looks like this:
        #define PaHub_I2C_ADDRESS  0x70
        #define ENV_I2C_ADDRESS    0x76
        PaHUB pahub;
          ez.begin();
          Wire.begin();
          pahub.address(PaHub_I2C_ADDRESS);
        I defined a struct for my sensors:
        struct Sensor {
          uint8_t channel;
          DHT12   device;
          char*   name;
        and an array of the struct which is initialized that way:
        struct Sensor sensors[] = {
          {0, DHT12(CELSIUS, ENV_I2C_ADDRESS), "Left"},
          {1, DHT12(CELSIUS, ENV_I2C_ADDRESS), "Hotspot"},
          {2, DHT12(CELSIUS, ENV_I2C_ADDRESS), "Right"},
          {3, DHT12(CELSIUS, ENV_I2C_ADDRESS), "Left"},
          {4, DHT12(CELSIUS, ENV_I2C_ADDRESS), "Hotspot"},
          {5, DHT12(CELSIUS, ENV_I2C_ADDRESS), "Right"}
        This is how I'm reading the sensors:
        struct SensorValues readSensor(int channel) {
          struct SensorValues sensorValues;
          struct Sensor sensor = sensors[channel];
          uint8_t returnCode = pahub.selectChannel(sensor.channel);
          Serial.println(" ---------- readSensor() ----------");
          Serial.print("pahub.selectChannel(");
          Serial.print(sensor.channel);
          Serial.print(") = ");
          Serial.println(returnCode);
          if (returnCode == 0) {
            sensorValues.temperature = sensor.device.readTemperature();
            sensorValues.humidity = sensor.device.readHumidity();
          return sensorValues;
        Unfortunately I'm receiving always 0 for both the temperature and the humidity.
        Could anybody please give me a hint what I'm doing wrong?
        Thanks & Best regards
        Thomas
        • m5stackM Online
          m5stack @thbonk
          @thbonk actually , the ENV Unit build-in two sensor IC. they I2C address is DHT12(0x5C) , BMP280(0x76), i saw your code. you was only define a 0x76 , but it is the BMP280 I2C address.
          thbonkT 1 Reply Last reply Reply Quote 1
          • thbonkT Offline
            thbonk @m5stack
            @m5stack I only want to read the temperature and the humidity of the sensors connected to the PaHUB.
            The M5Stck was connected to the Base BTC. The PaHUB was connected to the red Grove port and two ENV sensors were connected to channels 0 and 1 of the PaHUB. I then installed my application, but the ENV sensors connected to the PaHUB didn't deliver any values. When I queried the channels 2-5 of PaHUB I received values, but all were the same.
            So I disconnected the M5Stack from the Base BTC; afterwards I received the temperature and humidity of the two ENV sensors connected to channels 0 and 1 of the PaHUB.
            Is it somehow possible to connect the M5Stack to the Base BTC but read the sensors connected to the PaHUB? Or do I need the PbHUB to achieve this?
            Best regards
            Thomas
            • m5stackM Online
              m5stack @thbonk
              @thbonk in the I2C bus, you can't use two same address device at the same time. so if you connect the BTC to the BASIC, when the PaHUB switch channal select ENV Unit, it will working not normal. beacuse BTC and ENV all used DHT12, also has same I2C address
              • O Offline
                OffLineR
                I keep finding this thread whenever I search using ENV II over PaHUB, so instead of openning a new one I wanted to continue on this.
                I am new to development boards however I am an experienced platform developer.
                I have a Core2 and I want to use PaHUB and add couple of more units to read. I have no problem reading data via using Wire command over PaHUB like using 4way Relay.
                However, I have no idea how to use BMP and SHT over PaHUB. I have tried combining examples without any luck and tried above without any luck.
                Question is after portselect, how come bmp access to right address? If you can point me to any direcon, I will be grateful.
                Cheers.
                  roccoskye @world101
                  @world101 so the 1 to 3 Hub is used for 3 different i2C addresses?
                    capacious @roccoskye
                    @roccoskye Yes, the HUB makes it possible to connect more diferent I2C devices to the same port A. They all need to have different I2C addressess. The PaHub makes it possible to connect several sensors with the same I2C address and use them. On a HUB they would conflict and the system would know what sensor you'd be referencing to.
                      roccoskye @capacious
                      @capacious Ah ok thanks. Do you know how to use the 1 to 3 Hub because when i connect 3 devices to the hub i get the error message: Please change unit to other grove. Do I need to select custom ports for these devices?
                        Kivlow
                        @m5stack said in [Solved] Connecting 3 ENV units via 1 to 3 Hub to M5 Stack:
                        0x76
                        i get a problem with Pa.HUB i connected to it ENV.III. I get Temp and Hum ok but i get -482827.3 for pressure.
                        What is wrong ??
                        • teastainT Offline
                          teastain @Kivlow
                          @kivlow Hi! I have some experience with the PaHub and ENV sensors.
                          Could you post your code (if it is Arduino IDE) or if it is too big, email me?
                            Kivlow
                            I use UIFlow
                            i get weard readings like -482827.3 when connect to pa.hub but connected direct to core 2 ewerything is ok
                              Cmon169
                              I just started learning how to code and would like to connect ENVIII Unit and Mini TVOC/eCO2 Gas Unit with the PA.HUB to the BASIC kit using the Arduino IDE.
                              Is there a simple tutorial in how to use the addresses provided in PA.HUB git?
                                There is generic information on the PAHubs product information page.
                                An almost identical project was on my list for last week but didn’t get around to it
