    I'm looking for an example using the Atom Lite with the HEX
    2 Posts 1 Posters 3.4k Views
    • W Offline
      wwhite
      Does anyone know where I can find an example using the Atom Lite with the HEX?
      https://docs.m5stack.com/en/unit/hex
      Thanks in advance,
      WW
      • W Offline
        wwhite
        Ok, I got the HEX RGB LED to work with the Atom Lite. Using the code below everything works as expected but there is an occasional stray LED lighting up in a completely different color. Does anyone know what might be causing that?
        from neopixel import NeoPixel
        from machine import Pin
        from time import sleep
        np = NeoPixel(Pin(26), 37)
        n = 0
        while True:
        np[n] = (0, 0, 0)
        if n < 36:
        n += 1
        else:
        n = 0
        np[n] = (10, 0, 0)
        np.write()
        sleep(0.2)
