Zigbee unit - examples and Micropython support
Hi Folks,
Just thought I'd try using UIFlow 2.0 with my Atom S3 before I go down the Arduino rabbit hole.
https://docs.m5stack.com/en/unit/zigbeeI noticed in the configuration panel on the left, it only had Pa.HUB, ENV, ENVII and ENVIII, not the Zigbee unit with the blue grove plug. So I might assume this unit is not supported in UIFlow 2 ?
I tried using the UART and got as far as:
from hardware import * uart0 = UART(0, baudrate=38400, bits=8, parity=None, stop=1, tx=2, rx=1) while True: if uart0.any(): print("\nFound Data:", end="") print(str(uart0.readline())) else: print(".", end="") sleep(1000)But given how proprietary the CC2630 is, I expect that's as far as I'm going to get.
I found these examples here in C:
https://github.com/m5stack/M5Stack/tree/master/examples/Unit/Zigbee_CC2630.. which do not show how to pair sensor and read data from them. Has anyone got examples of how to do this with the UART interface ?
Hi @Exie, have you managed to talk to the Zigbee unit through UART or managed to comprehend the example code given by M5Stack?
Regards,
Ameer
