    help needed to get started.
    39 Posts 5 Posters 75.9k Views
    • DR_Froggy_rDD Offline
      DR_Froggy_rD
      the zip file is not inside the folder.....
        Why is it looking in the pictures folder?
        M5Burner should be in the root user folder or the programs folder!
          DR_Froggy_rD
          Because it put the downloaded zipfile in here and extracted here...
            DR_Froggy_rD
            As it is not a msi installer but just an exe i had never a problem running an exe not from the program files folder. Also from the temp folder.
            It is not playing a role sofar. This would be for me the first time.... if this is mandatory one must write a step by step standard procedure as idiot proof as possible...
            Nevertheless i an sure trying to extract into the program file folder will not solve the missing patch file...my honest opinion.
              DR_Froggy_rD
              Hi adam, I saw your review of cores3, sad that this part is not as straight foreward as one can expect.if i reckon correctly you struggled to get uiflow burned to the device as well. I did not get gow you did it!
              But you erase first the mwmory using m5 burner.
              The boot load mode was quite tricky to trigger.seems like
              On the atom s3 i need to press the side button for 3 seconds and a green led is shining for 2 secs i however do not know if you started thw mode. It stays in this mode untill you power off.
                ajb2k3 @DR_Froggy_rD
                @dr_froggy_rd
                No it doesn't start in this mode. Thank you for watching the video.
                The second time it work fine.
                Connect to computer,
                Press and hold boot button for a few minuets and "Port ***** detected" will show,
                Click erase and wait,
                click write and wait,
                power down and rest the S3 device and UIFlow starts.
                  DR_Froggy_rD
                  Hi Adam, so: I unzip my file in programm subfolder.
                  open M5nurner .exe as administrator.I can update firmware list.... but still looking for the same patch in the unzipped folder: I have anotherjavascript error message:: It is not EPERM but ENOENT..
                  However I connected the s3 to it. and push the left side button until green led flashes....then connect com6 (the detected port com there it is green) It fails to erase or to burn. failed to get mac. also when reducing the baud rate to 11000..
                  I tried even the easyloader software without success...
                    I refer to ENOENT as Error no Entity, it means something is missing probably in you background tools.It's possible you need ESPIDF or ESPTool installed but I can't remember
                      DR_Froggy_rD
                      Ok thks adam.
                      By the way i have a m5stick cplus. I could burn uiflow on it.
                      Does it mean then i can install any program made with uiflow on it?without needing to install the program via m5burner?from uiflow.
                      I am looking for the key of each part cannot find those i have the sn feom the label ...
                      By the way i printed the part yesterday and i neede to scale it a bit to fit the tailbat and a m5atom s3. Thank you for that you saved me time also i had to print it 3 times before getting the right dimensions.
                      It may be due to my printer tolerances! I will send you the dimension i used. Bye
                      Frog
                        DR_Froggy_rD
                        I have two stickv card what are those for.
                          @dr_froggy_rd You install UIFlow for the stickCplus to the StickCplus and the API key will be shown on the screen.
                            DR_Froggy_rD
                            thx Adam....As you said I found it..
                            I still do not know why it is not workimg with atom s3
                            voila
                              For the S3 Generation you need to hold down a button for several second to get it into boot mode, M5Burner will report a new port detected and then you can try accessing the settings.
                                DR_Froggy_rD
                                what the fuck esptool is not good. somehow
                                  DR_Froggy_rD
                                  It is not working with two Tom s3 i own to burn a firmware on it...
                                  So as it seems to be working on another iot dev kit, i will rather advice going for the stick c..
                                  Bsst Regards
                                  Frog Frog
                                    @dr_froggy_rd
                                    Have you held the boot button down until the green boot led lights up?
                                      DR_Froggy_rD
                                      Hi there so thanks to ajb2k3 I was able to burn the atoms3. the issue was a software one.
                                      which has been resolved so far by latest m5 burner update. Once I could log in onto my account from the software.
                                      Now I can even start to play with background colour as well but uiflow2 atom s3 misses a lot of subpart: i cannot get hardware imu to get pop up. however those are present on uiflow but I cannot run from uiflow.
                                      I see a remote m5 function which seems to be an interface for a smartphone.
                                      which can act as datalogger.. what I was intended to do...
                                      this is awesome.I f I can do that so easily but this is not as straight forward. the option do not appear on uiflow 2...0.17
                                        please see your other post and check out my YouTube video on the AtomS3 https://www.youtube.com/watch?v=2w85U4XwGj4&t=4s
                                          mtylerjr @DR_Froggy_rD
                                          @dr_froggy_rd
                                          "Uiflow redirect me tothe shop."
                                          Oh man, that loop of trying to figure that step out, and being redirected to the shop over and over was extremely frustrating. It was not a smooth customer experience.
                                            ajb2k3 @mtylerjr
                                            @mtylerjr said in help needed to get started.:
                                            @dr_froggy_rd
                                            I am not sure I understand what you mean here?
