    195 Posts 79 Posters 569.0k Views 13 Watching
      You need to click on "Hardware" under the picture of the Atom S3, then click on the hardware option to use it.IMU is there and was working.
      • DR_Froggy_rDD Offline
        DR_Froggy_rD
        I see- the page view was cropped too tight..
        I did reset those now I see those...
        this is idiotic but ar least I can get it now.
        I wanted to get the remote +
        Will it be enable in the future?
          alas, I don't know
            DR_Froggy_rD
            alas, I don't know
            what people use instead?
            • IAMLIUBOI Offline
              IAMLIUBO @sgu
              @sgu said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
              Ui Flow 2.0 looks nice. But it lacks functionality.
              Tested with a new Core S3 and wanted to test out the built in Camera. But how to do it either in micropython or with blockly ?
              New firmware support camera now :-)
              Once you start selling the devices, the software must be ready and support all features of the device.
              In my case I wanted to test the camera if it is possible to use the built in camera as a barcode reader, this would be a great application.
              Now it only supports basic functions such as image display, and does not support high-level functions such as recognizing barcodes.
              Second question to uiflow 2.0: Where have the examples gone ?
              Even as an experienced programme, the demos are a good starting point for testing out a device or a unit.
              We will add the example as soon as possible. Considering that it is still in the alpha stage, we still need to do the final API review. In short, we will add the example as soon as possible.
              Third question: How about the support of the stackable-modules for the Core S3 ? How to access them in the UiFlow 2.0 ? can we reuse the modules for the older M5 Stack models ?
              Yeah, any module or uint or hat will support in uiflow2.0, just need a little time to made this, sorry for this, we will do our best.
              • IAMLIUBOI Offline
                IAMLIUBO @teastain
                @teastain said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
                This issue? Seem fixed, thanks for report this!
                  Hello guys
                  I think in addition to the filters it would be beneficial to have some sort of sort order (e.g. alphabetically) for items listed under Software, Hardware and Unit.
                  The reason I am asking is that often times (also in UIFlow 1) I scroll through the Unit list up and down; missing the one unit I want to add multiple times before finally spotting it.
                    jhd2023
                    for the UI, it would really be a work-saver if you could create multiple UI pages that can then be easily switched.
                    IAMLIUBOI 1 Reply Last reply Reply Quote 2
                      joeoakes
                      Is there an estimated date when micropython code deploying/running using UiFlow 2.0 to the S3 will be supported? All our projects are written in micropython for the S2 and we cannot migrate over to the S3.
                        S3 devices are supported as that was the reason five the UIFlow2 version.
                          Hello @IAMLIUBO
                          M5CoreS3 - UIFlow2 alpha 21 - SDCard issues:
                          • the Init SDCard with block has everything pre-selected correctly except for CS. It should be GPIO4 (not GPIO3).
                          • when the program is Run a second time, it stops at the Init SDCard with block. I guess that is because the SDCard has already been initialized. After that the M5CoreS3 needs to be reset manually. What am I missing?
                          Apart from that I can access the SDCard and show the listing on the screen.
                            Graphics functions are not lining up.
                            • IAMLIUBOI Offline
                              IAMLIUBO @jhd2023
                              @jhd2023
                              yeah, but we need support lvgl first. if don't use lvgl it's very hard to manage the multiple pages.....
                              • IAMLIUBOI Offline
                                IAMLIUBO @joeoakes
                                @joeoakes said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
                                We already support many S3 boards, if you are use micropython develop the device, i think it will very easy migrate to S3, because micropython API is cross-platform?
                                  Hawksey
                                  No RGB LED in Units.
                                  Can you also add the ability to use HSL colour values to the RGB LED (as well as the existing RGB/Hex/Palette modes)?
                                    arkieguy
                                    Let me start by saying that I love the way UIFlow2 is going. It seems a lot more logical (with the ability to include selected software / hardware / etc features). With that said, I do have a few questions related specifically to the Atom S3 (with the display):
                                    • Any idea when (if?) the new Atomic QR-Reader will be added to UIFlow 2 (or docs for using it with the UART options)? I haven't had any luck with it so far (couple of hours playing around with it).
                                    • Is the LED light (behind the "reset" button) accessible? If I try to use the LED (BuiltIn) it throws an error.
                                    • I have a use case for the Atom S3 as a clock in an environment with no WiFi. The "RTC" functionality seems to "work" but isn't battery backed up. I've added a "Songhe DS3231SN Real Time Clock Module AT24C32" from Amazon that communicates via I2C (and has a rechargeable battery) but the RTC hardware doesn't have a way to point to the external RTC (seems to be pointing to the internal or maybe just pulling from WiFi when I have WiFi). Suggestions?
                                      flex
                                      @iamliubo said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
                                      @iamliubo
                                      Hi Liubo,
                                      • there is problem using the webpage UIFLow 2.0 on IOS: it is not possible to create or modify an UI item (it is working on UIFlow 1)...
                                      • more generally, what is the most efficient way to fill a bug report for UIFlow 2.0
                                      Thanks, Pascal
                                        ciconde
                                        I have a Servo2 with Core2 but I don't see it in "Modules".
                                        Can you please add it so we can use it?
                                          ciconde
                                          Several screen pages desired.
                                          Suggest to have several pages with different elements on them (like the scenes in Scratch) so it's easy to create a multi page application.
                                          Then an UI instruction for switchToPage(n) would disable and hide all elements but the ones pertaining to that page, potentially applying also separate background color.
                                            ciconde
                                            EzData2 Debugger wanted
                                            It would be great to have an EzData2 HMI such as we had in EzData1 "debugger".
                                            Thanks for such a great job!
