    DIY Mini Proto Board
    15 Posts 3 Posters 51.4k Views 1 Watching
      SR
      Yes, but currently only the housing 3D model for the proto board is available on github. So it would be helpful to make also the core and base as STL available there. My idea is to create a "housing" which would allow to fix the core incl. base plus this extension in/on it.
        Kryten
        @SR Here are a protoboard case STL file. If you are capable you can redesign and make for your own.
        https://www.thingiverse.com/thing:2754642
          SR
          @Kryten Thank you, this looks already good.
          Better would be the housing of the base board because I need to align the pin break out area with the stands of the proto board. But it's a beginning.
            Kryten
            @SR aWho big is your Proto board? any drawing?
              SR
              It's a standard 7x5 cm board with interconnected holes. The mini bread board on it measures ~ 4.5 x3.5 cm.
                Kryten
                Cool. I will see if can find the time to make a "shield" like that. So you just move the bottom PCB and battery (if needed) over to the printed version.
                  SR
                  My idea for a housing of the proto board would be more like a case that can pick up the complete M5Stack inclusive the button board without disassembling it at all.
                    Kryten
                    Like this?
                      SR
                      No. There is the button module completely replaced. I would like to keep it attached. I thinking about some kind of encloser around the housing of the M5Stack with a slide in mechanism. That was also the reason way I was asking in this thread for STL model of the hole case.
                        Kryten
                        So you want to hae the M5 as is and slide in to a module with your protoborad on?
                        Something like this?
                          SR
                          Yes, pretty close to your design.
