industrial friendly mechanical installation
Hi.
As I understand from your site You are pointing to the industrial IOT world .
I am using the M5Stack cores, modules and sensors for industrial machines and have sometimes a problem to install them physically because the mounting holes is for Lego (not very industrial grade) and not for normal bolts.
Also in some sensors there isn't any flat bottom that can be attached to a surface .
Maybe is time to decide if you are industrial or hobby oriented .Meir.
I would like similar M5Stack industrial in metal, proper IP protection, etc.
