    M5 Stack Core2 UI flow program stopped connecting to the WI-FI in the program.
    2 Posts 2 Posters 2.3k Views
      rob.driver1970
      Re: I can't connect the M5 Stack Core2 to WiFi in my program.
      It was working then one day I booted it up and it just stopped working. I saw the reply to a previous post about this and used the example with no results. I have tried to reflash but it did not help. It connects outside the program fine. it is a hidden network but like I said it was working before.
      Rob
        Connect a usb cable between the controller and the computer, open the terminal and run the program, the terminal may give you an error message to the problem
