    Micropython, CardComputer - issue reading Keyboard
    micropython
    8 Posts 5 Posters 8.6k Views
    • MartynWM Offline
      MartynW
      Hi, I've sucessfully installed the most recent ESP32S3 build of Micropython on my M5Stack CardComputer. Due to it being a generic build, there are no specific device drivers included with the firmware; however, I've managed to get some integrated peripherals working, ie the LCD, sdCard.
      The keyboard (schematic) in giving me some problems, its a pretty standard key matrix, the rows are provides using a 74hc138 3-8 line decoder, and the columns are 7 GPIOs. The outputs from the decoder are active low (datasheet), so I made the column pins inputs with pullups - doesnt work, needs pulldowns????
      Reading the column pins whilst iterating through the 8 rows should allow the individual key detection, but although key presses yield a pin change it doesn't work as expected and column 2 is always high???
          from time import sleep_ms
          from machine import Pin
           M5Stack CardComputer Keyboard
           74HC138 3 to 8 line decoder
           Decoder Pin   A2, A1, A0   ----\    Y6, Y5, Y4, Y3, Y2,  Y1,  Y0
           GPIO Pin     G11, G9, G8   ----/    G7, G6, G5, G4, G3, G15, G13
          class KeyBoard():
              def __init__(self):
                  keyPins = [ ('C0', 13, Pin.IN, Pin.PULL_DOWN), ('C1', 15, Pin.IN, Pin.PULL_DOWN), ('C2', 3, Pin.IN, Pin.PULL_DOWN),
                              ('C3',  4, Pin.IN, Pin.PULL_DOWN), ('C4',  5, Pin.IN, Pin.PULL_DOWN), ('C5', 6, Pin.IN, Pin.PULL_DOWN),
                              ('C6',  7, Pin.IN, Pin.PULL_DOWN),
                              ('A0',  8, Pin.OUT, None), ('A1', 9, Pin.OUT, None), ('A2', 11, Pin.OUT, None) ]
                  ap = dict()
                  for (name, pin, direction, pull) in keyPins:
                      self.pinMap[name] = Pin(pin, direction, pull)
              def scan(self):
                  for row in range(0,8):
                      self.pinMap['A0'].value( row & 0b001 )
                      self.pinMap['A1'].value( row & 0b010 >> 1 )
                      self.pinMap['A2'].value( row & 0b100 >> 2 )
                      sleep_ms(250)
                      print(f'{row:04b}\t',end='')
                      for col in ['C0', 'C1', 'C2', 'C3', 'C4', 'C5', 'C6']:
                          sleep_ms(0)
                          val = self.pinMap[col].value()
                          print(f'{val:01b} ', end='')
                      print('')
                  print('\n\n\n\n')
      keyboard = KeyBoard()
      while True:
          keyboard.scan()
          sleep_ms(500)
      Any ideas of where I'm going wrong??
        Hello @MartynW
        I tried your code and changed two things to make it work:
        • changed the inputs to pullups (as you already thought it should be) - the output matrix then is all 1s except for the button pressed.
        • used some additional brackets for A1 and A2 to force the AND operation to happen first
                    self.pinMap['A1'].value( ( row & 0b010 ) >> 1 )
                    self.pinMap['A2'].value( ( row & 0b100 ) >> 2 )
        Full code:
        class KeyBoard():
            def __init__(self):
              keyPins = [ ('C0', 13, Pin.IN, Pin.PULL_UP), ('C1', 15, Pin.IN, Pin.PULL_UP), ('C2', 3, Pin.IN, Pin.PULL_UP),
                          ('C3',  4, Pin.IN, Pin.PULL_UP), ('C4',  5, Pin.IN, Pin.PULL_UP), ('C5', 6, Pin.IN, Pin.PULL_UP),
                          ('C6',  7, Pin.IN, Pin.PULL_UP),
              self.pinMap = dict()
            def scan(self):
                    sleep_ms(250)
                        sleep_ms(0)
                    print('')
                print('\n\n\n\n')
            def scan2(self):
                for row in (7, 3, 6, 2, 5, 1, 4, 0):
                    sleep_ms(250)
                        sleep_ms(0)
                    print('')
                print('\n\n\n\n')
        while True:
            keyboard.scan()
        #    keyboard.scan2()
            sleep_ms(500)
        BTW: I like your coding style with the pinMap etc. (Note: I am not very familiar with Micropython.)
        MartynWM 1 Reply Last reply Reply Quote 1
        • MartynWM Offline
          MartynW @felmue
          Felix,
          Thank you for the extra pair of eyes much appreciated, I got so obsessed with the PULL_UP/PULL_DOWN issue, I didn't even consider the processing order of the bitwise logic!! Many thanks.
          Martyn
            felipeparaizo @MartynW
            Hello @martynw, I've been trying for a while to get my CardComputer's screen to work with Micropython code. I want to display a simple "hello world," but I'm having trouble. Could you help me? Could you show your code for activating the screen and writing anything on it?
              thijsnl
              Hello MartynW
              how do you use just the machine library. When I try this the m5stack gives an error.
              When I use the m5stack lib I don't have any problems with this
                ajb2k3 @thijsnl
                @felipeparaizo said in Micropython, CardComputer - issue reading Keyboard:
                Have you added a driver to control the screen?
                @thijsnl said in Micropython, CardComputer - issue reading Keyboard:
                Hello MartynW
                What's is the error?
                  felipeparaizo
                  @ajb2k3 said in Micropython, CardComputer - issue reading Keyboard:
                  Você adicionou um driver para controlar a tela?
                  Não, qual seria esse driver ? como posso adicionar ?
                    Você precisa fazer upload do driver Micropython para a tela ST7789V2 no micropython usando thonny.
