LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus
at initialisation, getting message:
File "unit/lorawan.py" line 7 in __init __ NameError name 'LoRaWan' isn't defineddoes someone has a workaround?
Just a point of interest but the unit is about to be replaced with an updated version soon
@felmue I'll check and let know, thanks
@ajb2k3 Great to know, but I hope anyway support of current version, not good to run about new versions when current version not stabilised and working. Thanks for info
Is there a way we can update the firware (I am using the EU version 868), or do we wait until the next drop of UiFlow?
Tim
@madefl Wait and see what is going to happen
@felmue said in LoRaWan_868 not working under UIFlow 2.01 on CoreS3 or SticC Plus:
here
I have followed the instructions and after changing the lorawan module as describe above (and managing to get the CoreS3 into bootloader mode, it is now loading the 'program' onto the device, with no errors.
Now just to get the LoRa connection working :-)
Many thanks.
Tim
Just looping back on this... (sort of).
I found the example of using a Core device as a LoraWan gateway, and it seems the code is only availe to load into the M5Core.
Being as the code was for an older version than the CoreS3 I have, I have looked around for the UIflow version of that example, but am unable to find it.Does anyone know if it existed and where it might be, so that I can compare it to what is available in UIFlow2 and update it?
Many thanks,
