    ENV IV Sensor with M5Atom (lite)
    11 Posts 4 Posters 7.8k Views
      Kees
      After trying several examples and combining several sketches I do not get the sensor working. In one example I get pressure, but with a large number (perhaps the order, I did not check that), not sure if it makes sense. I never succeeded in getting other values than 0 for temperature and humidity. I tried several atoms as well as several sensors. Somehow the combination of I2C:SHT40(0x44) and BMP280(0x76) should work.
      Does anyone has a simple example sketch that really works?
      • teastainT Offline
        teastain @Kees
        @kees What program language do you use?
        I have a ENV IV and a AtomS3 to try.
        Is yours a S3 model?
          Kees
          @teastain Hi, I use c++ with Arduino (IDE Microsoft Visual Studio and Visual Micro) and as far as I can tell I use the Atom Lite version. A basic version that I use for home automated applications. I expect both to work with the sensor. If you can shed some light on this I'd grateful.
          ajb2k3A teastainT 3 Replies Last reply Reply Quote 0
            ajb2k3 @Kees
            @kees said in ENV IV Sensor with M5Atom (lite):
            What's the error and are you sure you have the correct sensors as there are currently 5 different versions
            Does the sensor and ATOM lite work in UIFLow?
            • teastainT Offline
              teastain @Kees
              @kees The old Atom Lite is grey and the new AtomS3 Lite is white.
              It can make a difference!
              I will set up a test this afternoon with my AtomS3 and get back.
              Are you seeing these results on the Serial Monitor?
              • teastainT Offline
                teastain @Kees
                \o/
                is like playing Arduino IDE on 'hard mode'
                I use the new Arduino IDE ver2.3.x and I got it running on:
                AtomS3
                Stamp-Pico (which is about the same as the grey Atom Lite)
                And a generic ESP32
                I'm displaying in the Serial.monitor.
                16:23:46.537 -> Pressure=102.4
                16:23:46.537 -> Temp=23.21
                16:23:46.537 -> Humidity:40.32
                The pressure is in Pa, so I added this fix to make more sense and calibrate to my local atmosphere:
                Serial.println(pressure / 1000 + 3.6, 1);
                Gives 102.4 kPa, here in Southern Ontario Canada
                If you would tell me your Atom model I will post my sketch here:
                -Terry
                • felmueF Online
                  Hello guys
                  here is my example using M5Atom Lite.
                    Kees
                    Thanks Teastain (Terry) and Felmue (Felix),
                    Terry I am not sure what else I can tell than it is the M5Atom Lite! I would like to see your sketch. However it could basically be the same as Terry's.
                    Felix, thanks for your sketch. For some reason it fails on linking this: sht4x.begin(Wire, 0X44); I can not really see what is different in libraries. However I tried this: sht4x.begin(Wire). And this works well. At least I get readings that compare to the ones using another sensor (temperature and humidity). Perhaps the I2C address 0X44 is default.
                    Thanks both,
                    Kees.
                    • teastainT Offline
                      teastain @Kees
                      @kees If your Atom Lite has a Gray plastic body the try this sketch that I tested and it works!
                      #include <SensirionI2CSht4x.h>
                      #include <Adafruit_BMP280.h>
                      #include "Adafruit_Sensor.h"
                      Adafruit_BMP280 bmp;
                      SensirionI2CSht4x sht4x;
                      float temperature, pressure,
                        humidity;  // Store the vuale of pressure and Temperature.
                        Wire.begin(26, 32); // you may have to try other numbers, I do not have a gray Atom Lite!
                        Serial.begin(115200);
                        while (!Serial) {
                          delay(100);
                        while (!bmp.begin(
                          0x76)) {  // Init this sensor,True if the init was successful, otherwise
                                    // false.
                          Serial.println(F("BMP280 fail"));
                          delay(500);
                        Serial.println(F("BMP280 test"));
                        uint16_t error;
                        char errorMessage[256];
                        sht4x.begin(Wire);
                        uint32_t serialNumber;
                        error = sht4x.serialNumber(serialNumber);
                        if (error) {
                          Serial.print("Error trying to execute serialNumber(): ");
                          errorToString(error, errorMessage, 256);
                          Serial.println(errorMessage);
                        } else {
                          Serial.print("Serial Number: ");
                          Serial.println(serialNumber);
                        bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,
                                        Adafruit_BMP280::SAMPLING_X2,
                                        Adafruit_BMP280::SAMPLING_X16,
                                        Adafruit_BMP280::FILTER_X16,
                                        Adafruit_BMP280::STANDBY_MS_500);
                        uint16_t error;
                        delay(500);
                        error = sht4x.measureHighPrecision(temperature, humidity);
                        if (error) {
                          Serial.print("Error trying to execute measureHighPrecision(): ");
                        } else {
                          Serial.print("Pressure=");
                          Serial.print("Temp=");
                          Serial.println(temperature);
                          Serial.print("Humidity:");
                          Serial.println(humidity);
                          Serial.println("   ");
                        pressure = bmp.readPressure();
                        delay(500);
                      Cheers, -Terry
                        Kees @teastain
                        @teastain Thanks, this is indeed basically the same as Felmue (Felix) has and it works also.
                        I compared the readings with the readings from a CO2-sensor. Temperature is close to each other (difference of about max. 0.2 Celsius). But the humidity differs about 8-9%. That is a lot. The sensors are adjacent to each wonder and should not differ so much regarding humidity (compared to a mechanic sensor, the CO2 sensor comes closest (difference of about 2-3%)).
                        I wonder how reliable the readings really are.
                        Thanks for the support anyway!
                          I uploaded an example to UIFlow2 project zone on how to use the AtomS3lite and ENIV in UIFLOW with MQTT last night
