    m5stack cardputer doesn't turn on.
    26 Posts 10 Posters 31.6k Views
    • robskiR Offline
      robski
      @Sl4sh00 can you try this...press and hold boot button (on side of cardputer or top of stamp) while holding connect usb then let button go, then try to load fresh firmware in M5Burner.
      Sl4sh00S 1 Reply Last reply Reply Quote 0
      • Sl4sh00S Offline
        Sl4sh00 @teastain
        @teastain marauder
        • Sl4sh00S Offline
          Sl4sh00 @robski
          @robski I tried holding down the reset button but nothing happened, is there any other way to install the firmware?
          • teastainT Offline
            teastain @Sl4sh00
            @sl4sh00 To put it into 'download' mode you can do as @robski suggested or:
            Press and hold the G0 Boot button...while holding it in, press and release the reset button, THEN release the G0 Boot.
            While doing this you can check the connection status in whatever burner app you are using.
            Please tell us if you can see the connection status AT ALL, this would be helpful in solving your problem.
            Sl4sh00S T D 3 Replies Last reply Reply Quote 2
            • Sl4sh00S Offline
              Sl4sh00 @teastain
              @teastain Thank you my brother, it works just like you said. Now it works again.
              • teastainT Offline
                teastain @Sl4sh00
                @sl4sh00 Thank you for getting back to us!
                • W Offline
                  willyam @teastain
                  @teastain bro thank u so mutch i tried it the whole day but nothing helped thank u so mutch , God bless you
                    twinturbo @teastain
                    @teastain i tried the same for my cardputer but no luck
                    • G Offline
                      gera5034 @Sl4sh00
                      @sl4sh00 said in m5stack cardputer doesn't turn on.:
                      m5stack cardputer doesn't turn on, after I connected it to the computer and tried to put an app on the M5Burner and it didn't turn on anymore and when I plug it into the computer it keeps connecting and
                      Comprei um cardputer para mim, quero saber como faço para instalar as aplicações do git hub, e só baixar e passar para o cartão sd .
                      • Sl4sh00S Offline
                        Sl4sh00 @gera5034
                        @gera5034 baixa o M5Burner no site da M5. nele vc põe a opção do cardputer e aparece os apps q funcionam nele.
                          daft1 @teastain
                          @teastain
                          hello just wondering is the screen going to be off the entire while doing this? and im wondering how do i reset the firmware with it bricked and the screen off? ive consitently tried the button thing and plugging in at same time, maybe not getting it right idk.
                          im on linux (chromebook) and i got the burner unzipped loaded up and i couldnt get the cardputer to go onto the os files system i could only find it through port and in the linux usb sharing.
                          so i instead tried to download the firmware onto the local machine and then to the device in thw port and then it turned off when i did it. did i add one firmware o to the other making it brick or crash or just sent to cardputer bad?
