Arduino code for PaHuB2 + any I2C sensor
Dear all,
I looking for the sample code reading the values from the I2C module (like ENV III) that is connected to the PaHUB2 socket 0 (PaHUB2 has I2C address 0x71).
Thank you.
Dear all,
I'm looking for the sample Arduino code to read the ENV III module that is connected to the PaHUB2 socket 0 (PaHUB2 has an I2C address 0x71).Thank you.
@ektan Sorry, this took me all day to write and de-bug.
It is an ENVIII on position 0 and ENVII on position 1, as that is what I have!#include <M5Stack.h> //use any controller by substituting the library #include "M5_ENV.h" SHT3X sht30; // creates ONE instance!!! float tmp1 = 12.3; float hum1 = 0.0; float tmp2 = 12.3; float hum2 = 0.0; void setup() { M5.begin(); M5.Power.begin(); delay(100); Wire.begin(); sht30.init(); Wire.beginTransmission(0x70); //(the PaHub) Wire.write(0x00); //turns off all ports Wire.endTransmission(); // as it says! M5.Lcd.setTextSize(3); //or lower for StickC M5.Lcd.setTextColor(RED); M5.Lcd.print("Setup "); delay(1000); } void loop() { Wire.beginTransmission(0x70); //(the PaHub) Wire.write(0x01); //turns on port 0, ENV1 Wire.endTransmission(); if (sht30.get() == 0) { // Obtain the data of shT30. tmp1 = sht30.cTemp; // Store the temperature obtained from shT30. hum1 = sht30.humidity; // Store the humidity obtained from the SHT30. } else { tmp1 = 0, hum1 = 0; } delay(100); Wire.beginTransmission(0x70); //(the PaHub) Wire.write(0x02); //reads the ENV at port 1 Wire.endTransmission(); if (sht30.get() == 0) { // Obtain the data of shT30. tmp2 = sht30.cTemp; // Store the temperature obtained from shT30. hum2 = sht30.humidity; // Store the humidity obtained from the SHT30. } else { tmp2 = 0, hum2 = 0; } delay(100); M5.Lcd.fillRect(0, 0, 320, 80, BLACK); M5.Lcd.setCursor(5, 5); M5.Lcd.print("Temp1= "); M5.Lcd.setCursor(130, 5); M5.Lcd.print(tmp1, 1); //one decimal place M5.Lcd.setCursor(5, 50); M5.Lcd.print("Temp2= "); M5.Lcd.setCursor(130, 50); M5.Lcd.print(tmp2, 1); //one decimal place delay(1000); }There is no PaHub library because the Wire C-code is in-line with the Arduino code.
This is actually easier to understand and illustrates how the PaHub works.
-Terry -
Thank you so much for the help.
It works perfectly... -
@teastain In Arduino you can uise the PCA9548 library .
Example : https://randomnerdtutorials.com/tca9548a-i2c-multiplexer-esp32-esp8266-arduino/
