    195 Posts 79 Posters 569.2k Views 13 Watching
    • dissyD Offline
      dissy @BritOnTour
      @britontour You may wish to completely start over with the pairing process.
      1. Put your device in programming mode and use m5burner to do an 'erase'
      2. In uiflow2, click the button to select a device to connect to, and hover the mouse over your device icon. In the top right of that icon (when hovered over) should be a square you can click to edit the device info. In there should be an 'unregister device' button to fully delete it.
      3. Back in m5burner, reflash uiflow2 to the device and configure for your wifi.
      Be sure to keep the 'public' switch on this time.
      When the flash is done, keep the usb cable attached, hit reset on your device to get into the uiflow menu, and open uiflow2 in your browser again.
      Click the button to select a device. In a few seconds it should show in the 'public' list with a green dot. Be sure to select it here and not under the usb devices list. Unplug the device from USB.
      You should now be able to turn the device on/off and the device button in uiflow2 will go green/orange to reflect it is paired properly.
      • W Offline
        Waittherack
        Back to my problem, with a potential solution which i need help about ; My dad wondered if, instead of downloading the images inside the Core's memory, we could just use them from the SD card with a block "Execute mpy code", in which i type : "ImageTest.setImage("sd/AutresImages/Start.jpg")", which should set, theorically, Start.jpg as my image, since it's contained in the file "AutresImages" in the sd card, right ?
        But it doesn't work. No errors or stuff, it just doesn't :/
        Anyone has an idea ?
        robskiR dissyD 2 Replies Last reply Reply Quote 0
        • robskiR Offline
          robski @Waittherack
          @waittherack said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
          check this re: size/name/ etc limits
          sd card image
          • dissyD Offline
            dissy @Waittherack
            @waittherack Make sure to also add an "execute (eg import)" block to with:
            from hardware import sdcard
            I also had the FileIO option under Software turned on, but not sure if that's needed just to reference a file by path.
            • B Offline
              BigAl2301
              I'm trying to build a multi-character string from keystrokes but the only way I see is with ByteArray. However ByteArrary doesn't hold strings so I used ENCODE and DECODE as shown in this test code. Maybe this is not how encode and decode work?![alt text](0_1710453182467_Screenshot 2024-03-14 at 5.43.07 PM.png image url)0_1710453189687_Screenshot 2024-03-14 at 5.43.56 PM.png
              • dissyD Offline
                dissy @IAMLIUBO
                @iamliubo Feature request for UIFlow 2.0.2 on Cardputer
                On the main menu, can the characters on the arrow key buttons also be assigned to perform navigation?
                IE so pressing right (Function + arrow) or pressing forward-slash (the same button without holding Function) both navigate right, and the same for left / comma?
                It would also be nice to have that functionality in the App.list menu with the up/down arrows (semi-colon and period respectively)
                This way screens that only respond to arrow keys can be navigated without having to hold the Function key.
                (Note: The new behavior makes perfect sense for screens using both cursor navigation as well as text-input, eg the wifi settings, where holding Function for navigation should remain required)
                • B Offline
                  BritOnTour @BigAl2301
                  @bigal2301 Use a list instead of bytearray to hold the characters, then use "make text from list" to assign the list of characters to your string variable
                  • B Offline
                    BritOnTour @dissy
                    @dissy said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                    I'm stuck at step 3. I connect to the device in WebBurner (you say m5Burner, but that doesn't support S3), then click on "Configure" and enter the wifi credentials. When I click Confirm, I get an error message:
                    Error
                    Request failed. Check the network and try again!
                    Looking in the developer tab of Chrome, there is a 404 error attempting to download from https://uiflow2.m5stack.com/m5stack/api/v2/device/downloadBin
                    Is this a server issue, or a problem with my connection?
                    • B Offline
                      BritOnTour @BritOnTour
                      @britontour I found the m5burner that supports S3. I had an older version for my original Core, and didn't realize there was a new version.
                      It took a couple of tries, but I managed to bind and reflash the S3. I confirmed that the PUBLIC switch was active before flashing. Once complete, my screen still shows is at a PRIVATE device, and uiflow2 still shows a red dot next to it in the public list. The device info also shows it as PUBLIC. uiflow2 will not connect to it.
                      dissyD 1 Reply Last reply Reply Quote 0
                      • dissyD Offline
                        dissy @BritOnTour
                        @britontour If m5burner registered the device into uiflow, and it shows having a MAC and Token value (partially masked out), then it should be re-paired properly.
                        I'm unsure why your device can not connect to the server to report itself online.
                        I've just verified the process still works (I don't have a core s3 but used a cardputer which is stamp s3 based)
                        I did just discover a bug in the 2.0.2 "develop" screen. It may be cardputer specific, but it incorrectly displays "private" in both modes. It's just a display bug though, it isn't effecting my connection
                        • B Offline
                          BritOnTour @dissy
                          @dissy I see "PRIVATE" on the Develop screen of the S3, even though I configured it as Public. This is what I see in uiflow2 GUI when I click on the device button.
                          What server connection does it need? I may need to get IP or ports whitelisted at my office.
                          • B Offline
                            BritOnTour
                            My only way to connect to my S3 is USB cable. I click on the run button, and a web terminal window appears. I select the COM port and press connect. Press the play button at the top and I see my python code downloading. at the end , I get an error message (see below). If the line number is referring to my python code, I don't see what the problem is.
                            Line 68: rectOrigin = None
                            Line 102: if lengthTargetCycles >= 3:
                            Line 103: txtTargetCycles3.setText(str(listTargetCycles[2]))
                            File "<stdin>", line 68
                            SyntaxError: invalid syntax
                            Occasionally, the line number changes.
                            File "<stdin>", line 102
                            • dissyD Offline
                              dissy @BritOnTour
                              @britontour said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                              Before it connects it will read "private" in yellow, and show "user account" as "none"
                              After it successfully connects this will change and should show "public" in green and your email address in "user account"
                              https (port 443) to host uiflow2.m5stack.com
                              • B Offline
                                BritOnTour
                                My IT guy helped me work out the issue with the connection to the server. Access to ntp.aliyun.com was blocked. I changed it to our local gateway ntp server and I can connect to the S3 successfully over wifi!! Onto the next bug!!
                                • B Offline
                                  BritOnTour
                                  A new Bug!
                                  What does this mean? It doesn't change from 0%
                                  • B Offline
                                    BritOnTour
                                    My issue with Sync is also fixed. It was another issue with aliyun.com access restriction by my company's IT dept
                                    • B Offline
                                      BritOnTour
                                      OK, so I am finally making progress with my design, and I see so many features missing that really should be available for a modern development environment. There is no option for design reuse, code sharing, custom functions, etc. If I want to use some example code, I have to recreate each step in my project.
                                      Moving from uiflow1 to uiflow2, I had to rebuild every block of my design. If I find something useful in an example project, I can't just copy/paste from one window to the other, again, I have to manually rebuild what I want in my project.
                                      Is there a roadmap for planned features to be added to uiflow2?
                                      • teastainT Offline
                                        teastain @BritOnTour
                                        @britontour Maybe it is time for you to expand into Arduino IDE where all your complaints are answered.
                                        -Cheers
                                          Kris @IAMLIUBO
                                          @iamliubo Why only DAC hat is available with m5staick? No more hats?
                                          ajb2k3A 1 Reply Last reply Reply Quote -1
                                            ajb2k3 @Kris
                                            @kris said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                                            Because it take time to write and develop the code so that it doesn’t cause breakers in other code
