M5 BugC2 default software functions
What functions does BugC2 kit's default software have?
I got this new kit yesterday and try to test it. I pressed button B to switch among 3 screen frames, RGB function does lighting the LED on BugC2 and change it's color, the other 2 can show battery voltage. I'd like to know whether the motor can work. Does the default software burnt to StickC-Plus2 of this kit drive motor? I try to find any documents about this but failed. -
@俺がガンダムだ You are probably just seeing the Product Demo and test firmware. Almost all M5Stack products are 'ready to be programmed' but do very little outside the box.
Use UIFlow or Arduino IDE to add functions of your own choice and your own design.
https://docs.m5stack.com/en/app/BUGC2
https://github.com/m5stack/M5Hat-BugC
