    i2c read timeout issue while reading Pb hub through atom lite in ESP-IDF
    Scheduled Pinned Locked Moved ESP - IDF
    2 Posts 2 Posters 2.9k Views
      Akbarshah
      hey there, i am using ESP-IDF to program the atom lite, i have a Pb hub and i want to configure it with atom lite using the espidf, but the issue is i am getting read timeout error (error code 0x107) below is the code i am using.
      #include <stdio.h>
      #include "esp_log.h"
      #include "driver/i2c.h"
      static const char *TAG = "i2c-simple-example";
      #define I2C_MASTER_SCL_IO 32 /*!< GPIO number used for I2C master clock /
      #define I2C_MASTER_SDA_IO 26 /
      !< GPIO number used for I2C master data /
      #define I2C_MASTER_NUM 0 /
      !< I2C master i2c port number, the number of i2c peripheral interfaces available will depend on the chip /
      #define I2C_MASTER_FREQ_HZ 400000 /
      !< I2C master clock frequency /
      #define I2C_MASTER_TX_BUF_DISABLE 0 /
      !< I2C master doesn't need buffer /
      #define I2C_MASTER_RX_BUF_DISABLE 0 /
      !< I2C master doesn't need buffer */
      #define I2C_MASTER_TIMEOUT_MS 1000
      #define MPU9250_SENSOR_ADDR 0x61 /*!< Slave address of the MPU9250 sensor /
      #define MPU9250_WHO_AM_I_REG_ADDR 0x61 /
      !< Register addresses of the "who am I" register */
      #define MPU9250_PWR_MGMT_1_REG_ADDR 0x6B /*!< Register addresses of the power managment register */
      #define MPU9250_RESET_BIT 7
      • @brief Read a sequence of bytes from a MPU9250 sensor registers
        static esp_err_t mpu9250_register_read(uint8_t reg_addr, uint8_t *data, size_t len)
        esp_err_t err = ESP_OK;
        err = i2c_master_write_read_device(I2C_NUM_0, MPU9250_SENSOR_ADDR, &reg_addr, 1, data, len, I2C_MASTER_TIMEOUT_MS / portTICK_RATE_MS);
        return err;
        static esp_err_t i2c_master_init(void)
        i2c_config_t conf = {
        .mode = I2C_MODE_MASTER,
        .sda_io_num = I2C_MASTER_SDA_IO,
        .scl_io_num = I2C_MASTER_SCL_IO,
        .sda_pullup_en = GPIO_PULLUP_ENABLE,
        .scl_pullup_en = GPIO_PULLUP_ENABLE,
        .master.clk_speed = I2C_MASTER_FREQ_HZ,
        i2c_param_config(I2C_NUM_0, &conf);
        i2c_set_timeout(I2C_NUM_0, 400000);
        return i2c_driver_install(I2C_NUM_0, conf.mode, I2C_MASTER_RX_BUF_DISABLE, I2C_MASTER_TX_BUF_DISABLE, 0);
      void app_main(void)
      uint8_t data[2];
      ESP_ERROR_CHECK(i2c_master_init());
      ESP_LOGI(TAG, "I2C initialized successfully");
      while (1)
          esp_err_t err = mpu9250_register_read(0x00, data, 1);
          if (err != ESP_OK)
              int timevalue;
              i2c_get_timeout(I2C_NUM_0, &timevalue);
              ESP_LOGI(TAG, "time value is : %d  err[%d]", timevalue, err);
          ESP_LOGI(TAG, "WHO_AM_I = %X", data[0]);
          vTaskDelay(2000 / portTICK_PERIOD_MS);
      ESP_ERROR_CHECK(i2c_driver_delete(I2C_NUM_0));
      ESP_LOGI(TAG, "I2C unitialized successfully");
      Note : interestingly i am able to read and write the Pb hub using the arduino ide wire library so i am confused what could be the issue.
      i have go through all the documentation and help i could get online to resolve the issue but i am unable to solve it. any help in this regard would be highly appreciated.
        that_design_student
        can you try adding ESP_ERROR_CHECK(esp_event_loop_create_default()); and see what errors you get?
        When I compile and deploy my project, I see the following warning
        i2c: This driver is an old driver; please migrate your application code to adapt driver/i2c_master.h,
        which causes my system to never finish initialization. In my case, the M5Unified library needs to be updated to use driver/i2c_master.h
        Perhaps your timeout is related to the loop never initializing. At this point, I am only guessing what the issue might be.
