    Assistance Request: M5Core2 and 4-Relay Unit
    3 Posts 2 Posters 1.6k Views
    • W Offline
      wanderingchimp
      Good morning! I am trying to perform a simple test by flashing the LEDs and cycling the relays on a 4-relay unit board, and for some reason, the magic isn't happening, below is my code:
      #include <M5Core2.h>
      #include "Unit_4RELAY.h"
      UNIT_4RELAY relay;
        // Init M5Core2 And the I2C port(21,22).
        M5.begin(true,false,true,true);
       // Draw screen
        M5.Lcd.setCursor(0, 10);
        M5.lcd.setTextSize(2);
        M5.lcd.setTextColor(GREEN);
        M5.Lcd.printf("Hello World!");
        // Relay
        relay.Init(1);
           relay.relayAll(1);
           relay.ledAll(1);
           delay(2500);
           relay.relayAll(0);
           relay.ledAll(0);
      Any reason as to why this wouldn't work? The device is plugged into Port A on the M5Core2. Additionally, using wire scan, I am able to detect the device successfully on the I2C bus. I based my code off of this:
      https://github.com/m5stack/M5Unit-RELAY/blob/master/examples/Unit_4RELAY_M5Core2/Unit_4RELAY_M5Core2.ino
      Additionally, this is the specific module I am using:
      https://shop.m5stack.com/products/4-relay-unit
      Thanks in advance!
      • felmueF Online
        Hello @wanderingchimp
        the example is missing a relay.begin() call before the relay.init(). I've created a PR for that.
        Also for me it only works if I call relayAll() only. If I call both relayAll() and ledAll() as in your example it doesn't work for me.
        • W Offline
          wanderingchimp @felmue
          Thanks for the help! I've got it working now :)
