ENV IV Unit not working with firmware V2.0.8
I did not succeed to make my ENV IV unit working with Firmware V2.0.8.
Same issue with a M5Dial and a M5StickCThe code (for StickC)
import os, sys, io import M5 from M5 import * from hardware import * from unit import ENVUnit label0 = None i2c0 = None env4_0 = None def setup(): global label0, i2c0, env4_0 M5.begin() label0 = Widgets.Label("label0", 4, 26, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) i2c0 = I2C(0, scl=Pin(33), sda=Pin(32), freq=100000) print(i2c0.scan()) env4_0 = ENVUnit(i2c=i2c0, type=4) label0.setText(str(env4_0.read_temperature())) def loop(): global label0, i2c0, env4_0 M5.update() if __name__ == '__main__': try: setup() while True: loop() except (Exception, KeyboardInterrupt) as e: try: from utility import print_error_msg print_error_msg(e) except ImportError: print("please update to latest firmware")The output :
[68, 118]
File "<stdin>", line 22, in <module>
File "<stdin>", line 15, in setup
File "unit/env.py", line 1, in init
File "driver/bmp280.py", line 113, in init
ValueError: device not foundHowever, the 2 sensors are well detected during the I2C scan ( 68 is the SHT40, 118 is the BMP280).
With Firmware V2.0.7, no issue for both devices.
F felmue referenced this topic on
I had this too and messaged M5stack, they said it is a bug since the new firmware 2.08 and they are fixing it.
2.07 works fine with it.
Thanks,
Matthew
Hi guys
please try v2.0.9 which has the issue resolved.
