    m5stack ToF vl53l0x unit will stop scanning I2C devices
    11 Posts 3 Posters 27.2k Views 1 Watching
    • V Offline
      vvs551
      When m5stack ToF sensor is connected to Gray Core, i2c_scanner could not find/detect internal Mpu9250
      The scanning is stopping at :
      "I2C device found at address 0x29 !"
      If we will connect GYVL53L0X module from other supplier, we will get correct scanning results:
      "I2C device found at address 0x68 !"
      • m5-docsM Offline
        m5-docs @vvs551
        @vvs551
        Hey, Here's my result. My Gray Core works well.
        https://github.com/tackelua/I2C_Scanner/blob/master/I2C_Scanner.ino
        M5Stack documentation URL
        https://docs.m5stack.com
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          vvs551 @m5-docs
          @watson without any chance for me
          With ToF unit connected:
          With disconnected ToF unit:
          What is 0x75 in your listing?
          • m5-docsM Offline
            m5-docs @vvs551
            @vvs551
            0x75 is the address of IP5306 IC. Because this IC is customized. It is designed to communicate with M5Core through IIC.
            • V Offline
              vvs551 @m5-docs
              @watson Did you mean battery extension?
              I have not 0x75 when scan I2C
              m5-docsM 2 Replies Last reply Reply Quote 0
              • m5-docsM Offline
                m5-docs @vvs551
                @vvs551
                Hey, IP5306 was built in M5Core board without battery extension.
                How about M5Core running with I2C_Scanner.ino without any unit?
                IP5306 was built in M5Core Fire, so the terminal will display two I2C addresses: 0x68(MPU9250), 0x75(IP5306).
                IP5306 was built in M5Core Basic, so the terminal will display one I2C address: 0x75(IP5306).
                • m5-docsM Offline
                  m5-docs @vvs551
                  @vvs551
                  What's the hardware version of your basic core?
                  • V Offline
                    vvs551
                    0_1548143397290_d5fe9e38-2c31-4edd-b090-5f320f23db88-image.png https://photos.app.goo.gl/xQVAn8TftW32pEfz9
                    • V Offline
                      vvs551 @m5-docs
                      @watson there is scanning just 0x68 without any units/
                      You can see this listing in previous post
                        PlayTheGame
                        @vvs551 Could you make a picture of the TOF PCB? The schematics are not yet available
                        I have a hypothesis on all this I2C issuses.
                        But before just to exclude software bugs, please check to use the latest ESP32 Arduino core, at least V1.0.1 https://github.com/espressif/arduino-esp32/releases including all the recent I2C fixes.
                        • V Offline
                          vvs551 @PlayTheGame
                          @playthegame thank you for help!
                          I updated esp32-arduino with this link - nothing happens
                          The same result - just 0x68 in I2C scanner listing(
