    Atom DTU NB-IoT2 issues.
    18 Posts 2 Posters 11.0k Views
    • cocoaC Offline
      cocoa @felmue
      Hello @felmue ,
      Thank you for informations and suggestions.
      For me it is clear that the module must be used as a product and sold, so I hope that the AT reset command will solve any stuck of the modem.
      M5stack has not yet released the examples in UIFLOW2 for this module, so the module is useless for those who want to use UIFlow2. The ones for Atom DTU UIFlow1 obviously don't work.
      I just can't use it with Arduino / Platformio too.
      Could you share your source code to make a http connection? It would be of great help to me to get out of this impasse.
      Thx.
        felmue @cocoa
        Hello @cocoa
        the http example from here is working for me with the one modification in TinyGSM I mentioned.
        You haven't shared the log with #define DUMP_AT_COMMANDS enabled - this might shed some light onto what going on at your end.
        I guess you haven't noticed my edited note above about the AT reset command AT+NRB which did not work for me. All I got was an ERROR.
        Here you can find my modification to reset SIM7028 via GPIO.
        BTW: have you ever tried to check the firmware version currently installed on your SIM7028? E.g. AT+CGMR? Maybe it needs an upgrade?
        cocoaC 1 Reply Last reply Reply Quote 0
        • cocoaC Offline
          cocoa @felmue
          Hi @felmue, sorry for delay.
          Here is the log with #define DUMP_AT_COMMANDS enabled .
                   Connected!
          14:23:54.308 > >>ATOM DTU NB MQTT TEST
          14:23:54.308 > AT+CICCID
          14:23:54.308 >
          14:23:54.308 > ERROR
          14:23:54.308 > CCID: ERROR
          14:23:54.308 > AT+CSQ
          14:23:54.314 >
          14:23:54.314 > +CSQ: 21,0
          14:23:54.314 >
          14:23:54.315 > OK
          14:23:54.315 > Signal quality: 21
          14:23:54.315 > Initializing modem...
          14:23:54.315 > [  1689][E][esp32-hal-gpio.c:102] __pinMode(): Invalid pin selected
          14:23:54.321 > E (1581) gpio: gpio_set_level(227): GPIO output gpio_num error
          14:23:54.621 > E (1881) gpio: gpio_set_level(227): GPIO output gpio_num error
          14:23:59.621 > AT
          14:23:59.624 >
          14:23:59.624 > OK
          14:23:59.624 > ATE0
          14:23:59.628 >
          14:23:59.629 > OK
          14:23:59.629 > AT+CFUN=1
          14:23:59.636 >
          14:23:59.636 > OK
          14:23:59.636 > AT+QCLEDMODE=1
          14:23:59.641 >
          14:23:59.641 > OK
          14:23:59.641 > AT+CMEE=0
          14:23:59.645 >
          14:23:59.645 > OK
          14:23:59.645 > AT+CTZR=0
          14:23:59.649 >
          14:23:59.649 > OK
          14:23:59.649 > AT+CTZU=1
          14:23:59.653 >
          14:23:59.653 > OK
          14:23:59.653 > AT+CPIN?
          14:23:59.660 >
          14:23:59.660 > +CPIN: READY
          14:23:59.661 >
          14:23:59.661 > OK
          14:23:59.661 > Waiting for network...
          14:23:59.661 > AT+CREG?
          14:23:59.667 >
          14:23:59.667 > +CREG: 0,0
          14:23:59.668 >
          14:23:59.668 > OK
          14:23:59.918 > AT+CREG?
          14:23:59.924 >
          14:23:59.925 > +CREG: 0,0
          14:23:59.925 >
          14:23:59.925 > OK
          14:24:00.175 > AT+CREG?
          14:24:00.181 >
          14:24:00.181 > +CREG: 0,0
          14:24:00.182 >
          14:24:00.182 > OK
          14:24:00.432 > AT+CREG?
          14:24:00.438 >
          14:24:00.439 > +CREG: 0,0
          14:24:00.439 >
          14:24:00.439 > OK
          14:24:00.689 > AT+CREG?
          14:24:00.694 >
          14:24:00.695 > +CREG: 0,0
          14:24:00.695 >
          14:24:00.695 > OK
          14:24:00.946 > AT+CREG?
          14:24:00.952 >
          14:24:00.952 > +CREG: 0,0
          14:24:00.952 >
          14:24:00.952 > OK
          14:24:01.203 > AT+CREG?
          14:24:01.209 >
          14:24:01.209 > +CREG: 0,0
          14:24:01.209 >
          14:24:01.210 > OK
          14:24:01.460 > AT+CREG?
          14:24:01.466 >
          14:24:01.466 > +CREG: 0,0
          14:24:01.467 >
          14:24:01.467 > OK
          14:24:01.717 > AT+CREG?
          14:24:01.723 >
          14:24:01.724 > +CREG: 0,0
          14:24:01.724 >
          14:24:01.724 > OK
          14:24:01.974 > AT+CREG?
          14:24:01.980 >
          14:24:01.980 > +CREG: 0,0
          14:24:01.981 >
          14:24:01.981 > OK
          14:24:02.231 > AT+CREG?
          14:24:02.237 >
          14:24:02.238 > +CREG: 0,0
          14:24:02.238 >
          14:24:02.238 > OK
          14:24:02.488 > AT+CREG?
          14:24:02.494 >
          14:24:02.494 > +CREG: 0,0
          14:24:02.494 >
          14:24:02.495 > OK
          14:24:02.745 > AT+CREG?
          14:24:02.751 >
          14:24:02.751 > +CREG: 0,0
          14:24:02.751 >
          14:24:02.751 > OK
          14:24:03.002 > AT+CREG?
          14:24:03.008 >
          14:24:03.008 > +CREG: 0,0
          14:24:03.009 >
          14:24:03.009 > OK
          14:24:03.259 > AT+CREG?
          14:24:03.264 >
          14:24:03.265 > +CREG: 0,0
          14:24:03.265 >
          14:24:03.265 > OK
          14:24:03.516 > AT+CREG?
          14:24:03.521 >
          14:24:03.521 > +CREG: 0,0
          14:24:03.522 >
          14:24:03.522 > OK
          14:24:03.773 > AT+CREG?
          14:24:03.779 >
          14:24:03.779 > +CREG: 0,0
          14:24:03.779 >
          14:24:03.779 > OK
          14:24:04.030 > AT+CREG?
          14:24:04.036 >
          14:24:04.036 > +CREG: 0,0
          14:24:04.036 >
          14:24:04.036 > OK
          14:24:04.287 > AT+CREG?
          14:24:04.293 >
          14:24:04.293 > +CREG: 0,0
          14:24:04.293 >
          14:24:04.293 > OK
          14:24:04.544 > AT+CREG?
          14:24:04.549 >
          14:24:04.549 > +CREG: 0,0
          14:24:04.550 >
          14:24:04.550 > OK
          14:24:04.801 > AT+CREG?
          14:24:04.806 >
          14:24:04.806 > +CREG: 0,0
          14:24:04.807 >
          14:24:04.807 > OK
          14:24:05.058 > AT+CREG?
          14:24:05.064 >
          14:24:05.064 > +CREG: 0,0
          14:24:05.064 >
          14:24:05.065 > OK
          14:24:05.315 > AT+CREG?
          14:24:05.321 >
          14:24:05.322 > +CREG: 0,0
          14:24:05.322 >
          14:24:05.322 > OK
          14:24:05.572 > AT+CREG?
          14:24:05.578 >
          14:24:05.578 > +CREG: 0,0
          14:24:05.580 >
          14:24:05.580 > OK
          14:24:05.829 > AT+CREG?
          14:24:05.835 >
          14:24:05.835 > +CREG: 0,0
          14:24:05.835 >
          14:24:05.836 > OK
          14:24:06.086 > AT+CREG?
          14:24:06.091 >
          14:24:06.092 > +CREG: 0,0
          14:24:06.092 >
          14:24:06.092 > OK
          14:24:06.343 > AT+CREG?
          14:24:06.349 >
          14:24:06.349 > +CREG: 0,0
          14:24:06.349 >
          14:24:06.350 > OK
          14:24:06.600 > AT+CREG?
          14:24:06.606 >
          14:24:06.606 > +CREG: 0,0
          14:24:06.607 >
          14:24:06.607 > OK
          14:24:06.857 > AT+CREG?
          14:24:06.863 >
          14:24:06.863 > +CREG: 0,0
          14:24:06.864 >
          14:24:06.864 > OK
          14:24:07.114 > AT+CREG?
          14:24:07.120 >
          14:24:07.121 > +CREG: 0,0
          14:24:07.121 >
          14:24:07.121 > OK
          14:24:07.371 > AT+CREG?
          14:24:07.377 >
          14:24:07.377 > +CREG: 0,0
          14:24:07.378 >
          14:24:07.378 > OK
          14:24:07.628 > AT+CREG?
          14:24:07.634 >
          14:24:07.634 > +CREG: 0,0
          14:24:07.635 >
          14:24:07.635 > OK
          14:24:07.885 > AT+CREG?
          14:24:07.890 >
          14:24:07.891 > +CREG: 0,0
          14:24:07.891 >
          14:24:07.892 > OK
          14:24:08.142 > AT+CREG?
          14:24:08.147 >
          14:24:08.147 > +CREG: 0,0
          14:24:08.148 >
          14:24:08.148 > OK
          14:24:08.399 > AT+CREG?
          14:24:08.404 >
          14:24:08.404 > +CREG: 0,0
            felmue @cocoa
            Hello @cocoa
            from the output +CREG: 0,0 it looks like your modem is not registered to the network. According to the AT commands documentation, the second 0 in that answer means:
            0 not registered, MT is not currently searching for an operator to register to
            You could try to manually issue a 'AT+CEREG?' command to see if that yields any better result. Like I mentioned above, 'AT+CREG' didn't work for me either.
            The other AT command to see if the modem is actually connected or not is AT+COPS?.
            If you get something like this: +COPS: 1,2,"22801",9 it means your modem is connected. If you get: +COPS: 0 it is not connected.
            cocoaC 2 Replies Last reply Reply Quote 0
            • cocoaC Offline
              cocoa @felmue
              Hello @felmue,
              An interesting fact:
              • If I load the sample code you indicated the led of the modem continues to flash quickly without ever stopping , so it is correct to say that the modem is not connected .
              • If I erase the flash with the executable and restart the Atom DTU the modem after a few seconds connects autonomously with the cellular network.
              Therefore there is something in the source code of the http example that prevents the modem from connecting.
              • cocoaC Offline
                cocoa @felmue
                Hello @felmue,
                I think use AT+CREG? maybe it's not correct for NB-IoT connection on LTE technology.
                Should the modem probably use AT+CEREG? .
                What do you think? Should something be changed in TinyGSM?
                Thx.
                  felmue @cocoa
                  Hello @cocoa
                  actually I changed my fix to include sms only roaming state e.g. 7 like this:
                  //        return (s == REG_OK_HOME || s == REG_OK_ROAMING || s == REG_OK_SMS);
                          return (s == REG_OK_HOME || s == REG_OK_ROAMING || s == REG_OK_SMS || s == REG_OK_SMS_ROAMING);
                  The reason for that is that it seems to be a valid state for NB-IoT.
                  "7 Registered for "SMS only", roaming (applicable only when <Act>
                  indicates NB-IOT"
                  BTW: I've created a PR to that effect.
                  • cocoaC Offline
                    cocoa @felmue
                    Hello @felmue ,
                    I changed the header by inserting your change, but behavior uk the same of the previous on.
                    I edited the file using CEREG instead of CREG.
                    Something has changed but it is not yet possible to run the http example.
                    11:51:23.983 > AT+CICCID
                    11:51:23.983 >
                    11:51:23.983 > ERROR
                    11:51:23.983 > CCID: ERROR
                    11:51:23.983 > AT+CSQ
                    11:51:23.988 >
                    11:51:23.989 > +CSQ: 24,0
                    11:51:23.989 >
                    11:51:23.989 > OK
                    11:51:23.989 > Signal quality: 24
                    11:51:23.990 > Initializing modem...
                    11:51:23.990 > [  1689][E][esp32-hal-gpio.c:102] __pinMode(): Invalid pin selected
                    11:51:23.996 > E (1581) gpio: gpio_set_level(227): GPIO output gpio_num error
                    11:51:24.297 > E (1882) gpio: gpio_set_level(227): GPIO output gpio_num error
                    11:51:29.297 > AT
                    11:51:29.300 >
                    11:51:29.300 > OK
                    11:51:29.300 > ATE0
                    11:51:29.304 >
                    11:51:29.304 > OK
                    11:51:29.304 > AT+CFUN=1
                    11:51:29.311 >
                    11:51:29.312 > OK
                    11:51:29.312 > AT+QCLEDMODE=1
                    11:51:29.316 >
                    11:51:29.316 > OK
                    11:51:29.317 > AT+CMEE=0
                    11:51:29.320 >
                    11:51:29.321 > OK
                    11:51:29.321 > AT+CTZR=0
                    11:51:29.325 >
                    11:51:29.325 > OK
                    11:51:29.325 > AT+CTZU=1
                    11:51:29.329 >
                    11:51:29.329 > OK
                    11:51:29.329 > AT+CPIN?
                    11:51:29.335 >
                    11:51:29.335 > +CPIN: READY
                    11:51:29.336 >
                    11:51:29.337 > OK
                    11:51:29.337 > Waiting for network...
                    11:51:29.337 > AT+CEREG?
                    11:51:29.343 >
                    11:51:29.343 > +CEREG: 0,5
                    11:51:29.344 >
                    11:51:29.344 > OK
                    11:51:29.344 > success
                    11:51:29.344 > AT+IPADDR
                    11:51:29.352 >
                    11:51:29.352 > +IP ERROR: Network not opened
                    11:51:29.355 >
                    11:51:29.355 > ERROR
                    11:51:29.355 > Device IP address:
                    11:51:29.355 > success
                    11:51:29.356 > Performing HTTP GET request... AT+CIPCLOSE=0
                    11:51:29.363 >
                    11:51:29.364 > +CIPCLOSE: 0,4
                    11:51:29.365 >
                    11:51:29.365 > ERROR
                    11:51:29.365 > AT+CIPRXGET=1
                    11:51:29.371 >
                    11:51:29.371 > OK
                    11:51:29.371 > AT+CIPOPEN=0,"TCP","api.m5stack.com",80
                    11:51:29.382 >
                    11:51:29.382 > +CIPOPEN: 0,2
                    11:51:29.383 > failed to connect
                    11:51:39.383 > Performing HTTP GET request...
                    11:51:39.383 > ERROR
                    11:51:39.433 > AT+CIPCLOSE=0
                    11:51:39.440 >
                    11:51:39.440 > +CIPCLOSE: 0,4
                    11:51:39.441 >
                    11:51:39.441 > ERROR
                    11:51:39.442 > AT+CIPRXGET=1
                    11:51:39.447 >
                    11:51:39.448 > OK
                    11:51:39.448 > AT+CIPOPEN=0,"TCP","api.m5stack.com",80
                    11:51:39.458 >
                    11:51:39.458 > +CIPOPEN: 0,2
                    11:51:39.459 > failed to connect
                    11:51:49.460 > Performing HTTP GET request...
                    11:51:49.461 > ERROR
                    11:51:49.510 > AT+CIPCLOSE=0
                    11:51:49.517 >
                    11:51:49.518 > +CIPCLOSE: 0,4
                    11:51:49.518 >
                    11:51:49.519 > ERROR
                    11:51:49.519 > AT+CIPRXGET=1
                    11:51:49.524 >
                    11:51:49.524 > OK
                    11:51:49.525 > AT+CIPOPEN=0,"TCP","api.m5stack.com",80
                    11:51:49.535 >
                    11:51:49.535 > +CIPOPEN: 0,2
                    11:51:49.536 > failed to connect
                    11:51:59.537 > Performing HTTP GET request...
                      felmue @cocoa
                      Hello @cocoa
                      if you want to use NB-IoT mode I found you'll need to un-comment the define in TinyGsmClientSIM7028.h line 32 as well.
                      #define MODE_NB_IOT      //Comment this macro definition when using CAT mode
                      BTW: CAT mode (e.g. not NB-IoT mode) works for me too.
                      • cocoaC Offline
                        cocoa @felmue
                        @felmue It works in a totally random way, sometimes it gets the answer to the 'GET' and then it enters an infinite loop:
                         AT+CIPRXGET=4,0
                        07:25:49.725 >
                        07:25:49.727 > +CIPRXGET: 4,0,0
                        07:25:49.727 >
                        07:25:49.727 > OK
                        07:25:49.727 > AT+CIPCLOSE?
                        07:25:49.734 >
                        07:25:49.735 > +CIPCLOSE: 0,0
                        07:25:49.735 >
                        07:25:49.735 > OK
                        07:25:50.219 > AT+CIPRXGET=4,0
                        07:25:50.226 >
                        07:25:50.226 > +CIPRXGET: 4,0,0
                        07:25:50.227 >
                        07:25:50.227 > OK
                        07:25:50.228 > AT+CIPCLOSE?
                        07:25:50.234 >
                        07:25:50.234 > +CIPCLOSE: 0,0
                        07:25:50.236 >
                        07:25:50.236 > OK
                        07:25:50.720 > AT+CIPRXGET=4,0
                        07:25:50.727 >
                        07:25:50.728 > +CIPRXGET: 4,0,0
                        07:25:50.728 >
                        07:25:50.728 > OK
                        07:25:50.728 > AT+CIPCLOSE?
                        07:25:50.736 >
                        07:25:50.736 > +CIPCLOSE: 0,0
                        07:25:50.736 >
                        07:25:50.737 > OK
                        07:25:51.221 > AT+CIPRXGET=4,0
                        07:25:51.229 >
                        07:25:51.230 > +CIPRXGET: 4,0,0
                        07:25:51.230 >
                        07:25:51.230 > OK
                        07:25:51.230 > AT+CIPCLOSE?
                        07:25:51.237 >
                        07:25:51.237 > +CIPCLOSE: 0,0
                        07:25:51.238 >
                        07:25:51.238 > OK
                        07:25:51.722 > AT+CIPRXGET=4,0
                        07:25:51.730 >
                        07:25:51.731 > +CIPRXGET: 4,0,0
                        However, the library must be modified to be able to obtain a communication as it does not connect with the original commands.
                        I think the nb-iot command set in LTE is wrong.
                        It is also my opinion that an nb-iot device without a hardware reset cannot be used seriously.
                        Thanks for the helping.
