    Cores3 voltage problem
    5 Posts 2 Posters 2.6k Views
    • B Offline
      Bipman
      Hi
      I have a CoreS3 which I am trying to get the Env pro sensor working with. The Uiflow 2 example did not work in that it couldn't find the module. I measured the voltage on Port A (red) and it was only 0.5 V. Is it a defective unit?
      Bipman
        felmue @Bipman
        Hello @Bipman
        most likely external power is not turned on.
        Try Set external port power to output mode. You'll find that block under System - Power.
        • B Offline
          Bipman @felmue
          Thanks, I've just tried it and no difference. The code is :-
          I've noticed that the Python code does not change when I add the external port power item in.
          The voltage is still 0.5v though on the port. Am I missing something?
          Bipman
            felmue @Bipman
            Hello @Bipman
            try adding it after Init built-in hardware at beginning.
            In my case this line was added in the Micropython code:
            Power.setExtOutput(True)
            Note: make sure you have set Read mode on the Micropython tab; else blockly changes are not reflected.
            • B Offline
              Bipman @felmue
              @felmue That was it thanks! All working now.
              Bipman
