    Can we use GPIO36 as Servo control pIn ?
    Scheduled Pinned Locked Moved M5Stack Fire
    4 Posts 3 Posters 3.0k Views
      RuriObb
      Hello.
      I'm trying to use M5Stack FIRE V2.7 portB(GND, 5V, GPIO26, GPIO36) as Servo motor control pin. The purpose is that two Servo motors ( SG-90 ) connected to portB can be controlled by software.
      First of all, I tested one Servo motor connected to portB (GND, 5V, GPIO26) by using the following Arduino IDE sketch, and it works well.
      But the same Servo motor connected to portB (GND, 5V, GPIO36) doesn't work by using the same Arduino IDE sketch with replacing pin number 26 to 36.
      It seems that GPIO36 pin cannot be set to OUTPUT mode.
      #include <M5Stack.h> //Board : M5Stack-FIRE
      #include <esp32-hal-ledc.h>
      #define LOW 1500
      #define HIGH 8500
      #define TIMER_WIDTH 16
      #define PIN 26 // PIN should be set to 36, if GPIO36 is used
      pinMode(PIN, OUTPUT);
      ledcSetup(1, 50, TIMER_WIDTH);
      ledcAttachPin(PIN, 1);
      for(int i = LOW; i < HIGH; i = i + 100) {
      ledcWrite(1, i);
      delay(100);
      I don't know the reason why GPIO36 cannot be used as Servo motor control pin.
      Furthermore, I opened M5Stack FIRE cover, and connected Servo motor to GPIO pins directly, but the result is the same as ever.
      Please help, if you have any advice or information on it.
      Thank you In advance.
      RuriObb
      felmueF ajb2k3A 2 Replies Last reply Reply Quote 0
        felmue @RuriObb
        Hello @RuriObb
        ESP32 GPIO36 is one of the few pins which can only be used as input. See note here.
        GPI: GPIO34-39 can only be set as input mode and do not have software-enabled pullup or pulldown functions.
          RuriObb
          GPIO36がε…₯εŠ›ε°‚η”¨γ§γ‚γ‚‹γ“γ¨γ‚’η†θ§£γ—γΎγ—γŸγ€‚
          ζƒ…ε ±γ‚’γ‚γ‚ŠγŒγ¨γ†γ”γ–γ„γΎγ—γŸγ€‚
          RuriObb
            ajb2k3 @RuriObb
            @RuriObb No, it is an input pin only. as specified in the various my stack documents.
            With your input, this post could be even better πŸ’—
