    How do I charge the Cardputer?
    21 Posts 12 Posters 28.7k Views 1 Watching
      Trout1874
        A new battery may stay at 75% for a while as it take a few charge/discharge cycles for the power management chip to understand the battery.
        • B Offline
          BigAl2301
          Having the same issue. My guess is that the power management is not showing the correct charge level -- or that the level is correct because it hasn't been through a discharge/charge cycle yet.. Mine hovers around 78-80% after I've left it on my 30 watt USB charger for a while. I'm going to try to let it fully discharge and then charge again to see what happens.
            Hello guys
            my M5Cardputer takes about 7 hours for a full charge from a completely discharged battery state.
            Note: I soldered two LEDs to the charger IC CHRG and STDBY outputs and it switched from charging to standby after about 7 hours.
              JDEVW
              How exactly do I charge the M5 Cardputer, and does it come with a built-in charging indicator? I'm curious if there's an LED light or screen notification to show when it's charging or fully charged. Also, what should I look for to ensure it's properly connected to the USB-C cable, and are there any recommended practices for safely charging the internal battery? How long does it typically take to charge, and is there any way to monitor the battery level during use?
              felmueF D 2 Replies Last reply Reply Quote 0
                felmue @JDEVW
                Hello @JDEVW
                no, there are no stock built-in charging indicators. That said, they can be added. See here.
                If you look at the back of your M5Cardputer you'll see that the battery voltage can be monitored via G10.
                  DanielMoore @JDEVW
                  @JDEVW Got it! So, while there isn't a built-in charging indicator by default, you can monitor the battery voltage using G10 on the back of the M5Cardputer, and it's possible to add a custom indicator if needed. Thanks for pointing that out!
                  • I Offline
                    ivosak @ajb2k3
                    @ajb2k3 hello all!
                    Sadly I left Cardputer on my phone charger (which can charge my Z fold 5 in less than 2 hours) over night and not even 1% charged. Still 15%
                    Anny suggestion?
                    • robskiR Offline
                      robski @ivosak
                      @ivosak when you left it connected to charger was on/off button in ON position?
                      • PajdzianP Offline
                        Pajdzian
                        I use M5Launcher Cardputer software for charging. Charging time is significantly reduced.
                          felmue @Pajdzian
                          Hello @Pajdzian
                          I measure about 62 mA charging current (at the battery) when using M5Launcher and the same amount when running Cardputer UIFlow2 or Demo firmware (the one preloaded).
                          So I am curious: what other firmware did give you a slower charging rate?
                          • kurikoK Offline
                            kuriko @robski
