    How to add External Libraries - UIflow - Micropyton - Websockets
    6 Posts 6 Posters 8.8k Views 1 Watching
      Medy
      Hello I want to use external libraries ... for setting up a websocket connection...
      I have UIflow installed ... and dont know how to import external libraries for the m5stack ... i need a tutorial or smth
      • world101W Offline
        world101
        Copy the lib.py file to /flash and then use the execute block with import lib in the Setup section of the flow
          DevPeter
          Hello. I am currently trying to do similar of what @Medy was doing. @world101 how exactly would I do this in the way you stated? Thanks.
            pkayme
            Were you able to get websockets working with uiflow?
            • kurikoK Offline
              kuriko @pkayme
              @pkayme
              You should use microPython to import external libraries
                danber @kuriko
                I would be interested in the opposite way. How can I use the M5 library with the original micropython. "import M5" doesn't work.
                thank you
