    Add MCP9600 I2C Thermocouple Amplifier - K, J, T, N, S, E, B and R Type T
    Scheduled Pinned Locked Moved Features Wish List
    5 Posts 3 Posters 4.1k Views
      mgrouch
      • teastainT Offline
        teastain @mgrouch
        @mgrouch https://docs.m5stack.com/en/unit/kmeter
          mgrouch @teastain
          @teastain
          What can I do with that? Thermocouple is for measuring higher temperatures. This thing is plastic.
          Thermocouple for measuring exhaust temperature of a car engine looks quite different.
          teastainT H 2 Replies Last reply Reply Quote 0
          • teastainT Offline
            teastain @mgrouch
            @mgrouch You are so disappointed with M5Stack.
              holofloh @mgrouch
              @mgrouch KMeter is just the thermocouple converter. The TC insulation itself can be made from plastic or silicon or it can be made from glass fabric. It can also be inside a stainless steel housing or whatever. It depends on the application.
              I just did a quick search for exhaust thermosensors and there are many K-type thermocouple in different housing available. As long as they have a TC connector or open wires for mounting one by yourself you can use them with KMeter.
              I strongly recommend you to read the basics about thermocouples and how they work. You may than understand, that this "plastic thing" can be and should be far away from the high temperature exhaust.
              By the way: If you feel better with the MCP9600 then buy one from e.g. Adafruit and use it with its library in the Arduino environment. You controller can still be M5. As for the KMeter the MCP9600 breakout is not made to put in the exhaust as well.
