    M5Paper unusable
    14 Posts 7 Posters 8.0k Views 1 Watching
      turgu
      Hello all,
      I'm facing an issue I can't resolve. The M5Paper i bought sometimes ago refuse to start properly, Got that issue since I purchased the device. I've put it on the side for all that time and tried again to get it works since a week.
      Tried to install the testing application and the calculator from the M5Burner app. Erased the flash memory several times before burning the apps. Nothing happen on the screen. Looking at the code and monitoring the USB port, the IT8951 refuses to become ready to be programmed. (The WaitBusy() function returns a timeout status every time it is called).
      I'm desperate. Any clue on something I can do?
      • robskiR Offline
        robski @turgu
        @turgu have you erased and loaded latest firmware to it via M5Burner?
          turgu @robski
          @robski Yes, tried several applications. Burning is fine but nothing happen on screen. As indicated, the monitoring shown that the it8951 chip responsible of managing the screen refuses to become ready. As I'm a professional embedded developer, was also able to develop some code that manage properly the battery state, the buttons and the touchscreen. But the eInk screen controller refuses to become ready.
          • robskiR Offline
            robski @turgu
            @turgu shame, I do have myself one of M5Basic where lcd just stopped to work, all the rest works just fine except built in screen
            T 2 Replies Last reply Reply Quote 0
              turgu @robski
              @robski Was ready to buy a new M5PaperS3, but with this issue, I'm becoming less and less interested. I did built some software for the Inkplate eInk/esp32 based devices (an EPub reader and other stuff). This jeopardize my effort to port them to the M5Paper-ish devices.
                turgu @robski
                @robski You can have a look at the EPub reader I wanted to port here
                • robskiR Offline
                  robski @turgu
                  @turgu sounds like you went in bit too deep in to display firmware maybe? - joking -
                    turgu @robski
                    @robski At least on paper, the Inkplate devices are very similar in capabilities to the M5Paper. No reason to not being able to port the app, but hardware stability...
                    felmueF K 2 Replies Last reply Reply Quote 0
                      felmue @turgu
                      Hello @turgu
                      FWIW: in M5PaperS3 the eInk display is directly controlled by ESP32S3.
                      In M5Paper the GPIO WaitBusy() checks is GPIO27 which comes directly from IT8951 so I guess if the line never goes HIGH either IT8951 is not (properly) powered or defective.
                      Anyhow, have you tried to change the code to ignore the busy state of IT8951; maybe add some small delay instead.
                      BTW: I measured GPIO27 and when M5Paper is running it's being pulled up. I don't see a pull-up resistor in the schematics so I guess IT8951 is pulling it up (when not busy).
                        samlevy0515
                        That sounds frustrating! Since it's been an issue since purchase, it might be a hardware defect in the IT8951 controller. Try a 'nuclear reset'。 Disconnect the battery for 30 mins + hold power button to drain residual charge, then reflash.
                        Your trusted source for high-performance stepper motor and servo motor on https://www.stepperonline.co.uk.
                          king-333 @turgu
                          @turgu That sounds frustrating! Did you solve this problem?
                          • W Offline
                            wdehoog
                            In my application the m5paper goes to deep sleep and should wake after 5 minutes. Sometimes it appears to hang at startup and I also get a series of these messages:
                            [W][Panel_IT8951.cpp:258] _wait_busy(): [Panel_IT8951] wait_busy: timeout
                            As @felmu suggested it can be a pullup issue.
                            In M5GFX.cpp the busy pin is configured with:
                            lgfx::pinMode(GPIO_NUM_27, lgfx::pin_mode_t::input_pullup); // M5Paper EPD busy pin
                            However in Panel_IT8951.cpp (Panel_IT8951::init(bool use_reset)) the busy pin is configured with
                            pinMode(_cfg.pin_busy, pin_mode_t::input);
                            So it looks like the pin is incorrectly reconfigured and the required pullup is missing.
                            Now how can I override this behaviour in my application without having to modify the M5GFX.cpp file?
                            (I am using the Arduino IDE with M5GFX 0.2.17 and M5Unified 0.2.11.)
                            regards,
                            Willem-Jan
                            • W Offline
                              wdehoog @wdehoog
                              A fix has been submitted. See https://github.com/m5stack/M5GFX/commit/66df6c5f44d5867550d902923bf04ad6338d57cf
                              • wayner.dW Offline
                                wayner.d
                                M5Paper quirks can definitely slow you down. Curious what steps you’ve tried so far and if any improvements helped.
