AtomS3R bmm150 magnetometer readings
I'm getting really bad magnetometer readings from AtomS3R bmm150
using m5stack libraries.atan2(mag.x, mag.y) should give some reasonable result in radians.
However I do not see it being even close.
My code:
I think there is a bug in m5stack unified library which reads that sensor.
Thanks,
Hi there, I'm using an M5core2 with the GNSS module and getting really strange readings form the bmm150 as well. Did you find a fix ?
Best,
m5stack code for calibration is very primitive. It doesn’t do sphere fit. That’s the issue I had
@mgrouch I can use the M5Unified library to read a reasonable readings from the BMM150. Yet have to work on the orientation. In my case I have to invert the X-axis value and Z-axis value and able to calculate into a tilt-compensated headings
