๐Ÿค–Have you ever tried Chat.M5Stack.com before asking??๐Ÿ˜Ž
    Watering unit sensor calibration
    2 Posts 2 Posters 2.0k Views
    • G Offline
      gantini
      I am using the watering.ino example
      https://github.com/m5stack/M5Stack/blob/master/examples/Unit/WATERING/WATERING.ino
      How should I interpret the humidity sensor values? Is there a way to do a calibration? I get values โ€‹โ€‹of about 2100 for the sensor in air, 1800 if wrapped in a wet rag and 1500 if immersed in water.
      thanks
        ajb2k3 @gantini
        @gantini The sensor is a capacitive sensor and so the higher the reading the lower the moisture level.
        These are superior to the resistive sensors that rot easy but work the same way.
        With your input, this post could be even better ๐Ÿ’—
